Old 07-27-2016, 03:00 PM   #11
Where is thermister in DMR702?
Snip the tip would be nice upgrade is a person knew where the thermister is in the box. Just a thought! Only place I can think of is it's hidden in the door switch/light fixture at the front top of the fridge.
Charles & Martha Myatt
2009 Duramax w/Transfer Flow Fuel Tank
2016 Flagstaff V-Lite 30WFKSS
Almost South of the Border
whatsupchuck is offline   Reply With Quote
Old 07-28-2016, 05:20 PM   #12
Nothing on Dometic website shows where or if there is a thermistor. I can tell my compartment is not insulated well as the walls are quite hot. Can only see part of one wall from the outside.
Still would be nice to know what checks the temp. in the box and where it is.
Old 07-28-2016, 09:07 PM   #13
Head Rambler
The wiring diagram in the manual shows a thermistor plugged into the control board AT J3 with two white wires. It doesn't show where it's located however.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 07-29-2016, 04:08 PM   #14
Thanks for the suggestions everyone. It started working better once the temps got lower and humidity dropped. So I am thinking that some fan mod would be good to go.
SubVet is offline   Reply With Quote
dometic
