Old 08-05-2016, 09:03 PM   #1
mikier's Avatar
dometic fridge
how do you adjust the flame on the fridge. Gas / air adjustment to even blue flame
Mike,Patty & Sampson
2015 Chevy 2500 4x4 Diesel
2014 Puma 230FBS
2003 Four Winns 245 Sundowner
mikier is offline   Reply With Quote
Old 08-06-2016, 05:01 PM   #2
Head Rambler
What model fridge do you have?
Why do you think the flame needs adjusting?
There's really no way to 'adjust' the flame. You most likely need to clean out the burner tube and orifice. The Service Manual has the cleaning procedure on about page 19.
You may also want to check the system pressure.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-06-2016, 05:06 PM   #3
f5moab's Avatar
In the lower end 3-way fridges they put in popups, the say check for a predominately blue flame if not; jet needs to be cleaned.
f5moab is offline   Reply With Quote
Old 08-06-2016, 06:01 PM   #4
mikier's Avatar
DM 2652RBX
the flame is not consistent, on my last camper, the hot water heater had the same type of flame problem and I was able to adjust the air to the flame with an adjustable sleeve and get a smooth consistent flame. I was hoping their would be some kind of adjustment here.
on a different reply... where are these jets that can be changed
2014 Puma 230FBS
Old 08-07-2016, 07:57 AM   #5
waiter21's Avatar
There are no adjustments, but the orifice and burner tube can be cleaned.
I have the 2652 in my Mirada and uploaded the service and operation manuals on my web site (so I can find them when I'm traveling)
http://2001mirada.com/DOWNLOAD/Domet...ice_Manual.pdf
http://2001mirada.com/DOWNLOAD/Domet...fer_Manual.pdf
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2001 Civic
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
dometic, fridge
