10-10-2014, 05:49 PM
Dometic fridge
My fridge won't work on gas but is fine on AC. Cleaned the burner still not working. Now I'm thinking flue, any advice??????
10-10-2014, 10:32 PM
??? Does the stove light or the water heater? Does it try to light? Can you hear the igniter trying to light? Need more info
10-10-2014, 11:09 PM
Is propane tank valve open? Is tank empty?
2018 Forester 3011 DS
10-11-2014, 07:28 AM
Every thing else works fine. Just the fridge is the problem. And I have a nice blue flame at the burner. And the flue gets hot when running. ??????
10-11-2014, 08:36 AM
Make sure your flue is clean all the way thru, no bees nest, spider webs etc. check and make sure your roof vent is free and clear. I noticed on mine that there was insulation from the factory blocking art of it.
Fourn3833
2008 Georgetown SE TS
2013 Ram 1500 Longhorn  in tow
10-11-2014, 08:54 AM
Carbon build up will not allow the heat transfer to the cool- ing unit and cause lack of cooling on gas. The flue tube is welded to the boiler of the cooling unit. In a rough riding coach there have been rare cases where the weld will crack and create lack of cooling. The flue tube must be cleaned periodically, at least once a year. Clean by using a flue brush, Dometic Part No. 0151404001.
10-11-2014, 09:07 AM
Must have a air flow thru the condenser problem. Does yours have a fan? If so is it coming on?
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
10-11-2014, 11:18 AM
I'll clean the flue when I get home. Thinking this is the problem as it is running perfectly on AC. no it doesn't have a fan, but does it need one if its good on AC??????
10-11-2014, 11:24 AM
Ours has one that's why I was asking.
10-11-2014, 12:10 PM
Good question? Maybe I should put one in?
10-11-2014, 12:15 PM
It helps in real hot climates like we have here Texas
10-11-2014, 12:42 PM
Michigan not so hot. Frost this morning brrrrr
10-11-2014, 12:49 PM
88 here yesturday rain today.
02-05-2015, 12:26 PM
Mine is doing the same when I unplug from electric power all the lights go off an stops working when I plug back in lights come on.
