Glass fuse or blade type?
i had an older fridge that had a glass fuse and the the clips that held the fuse in were weak and didn't make good connection.
The fuse would get hot and actually melt the solder inside the fuse that held the wire.
Once discovered, I cleaned the clips and squeezed them tighter before reinserting the fuse and no more problems.
If blade type, sounds like something on the board is drawing too much current.
