Old 09-20-2014, 12:31 AM   #1
Dometic fridge check light at high elevation
We have a 2014 FR Stealth WA2313 with a Dometic 2852 fridge. While camping at 9,300 feet the fridge check light would be on when we got up in the morning also be on after returning from hiking. We were dry camping and running on propane.
I have researched this issue and know it is caused by elevation. However other people don't have this problem at similar elevations and our previous Greywolf with a Norcold would work fine at the same elevations.
Looking for advice on what my dealer can adjust to fix this. Thanks.
FR Stealth 2313
Chevy 2500HD Duramax
hammick is offline   Reply With Quote
Old 09-20-2014, 02:30 AM   #2
Witch Doctor's Avatar
This has come up before with that same refer. You could check the other thread but If I remember the orifice had to be changed. There is no real adjustment that can be made. You might want to call Dometic themselves. You are correct Norcold doesn't have this problem.
Coachmen M/H
Concord
2018 / 300 DSC
dometic, fridge, light
