Old 12-31-2018, 07:57 PM   #1
Aqualight's Avatar
Dometic Fridge DMR702 - Broken Trim/Flange/Gasket
Not sure what this part is called but it is the vertical piece that the door latch catches on to keep the door closed. It looks like a small notch is broken off. Any idea what this part is? Iím guessing it is some kind of trim kit. It looks like it would be an easy fix . Click image for larger version
ID:	193761Click image for larger version
As a wise man once said, "Wherever you go, there you are."
2018 Rockwood Roo 23IKSS
2018 Ford F-150 Super Crew Platinum
Previously owned a 2011 Rockwood Roo 19
Aqualight is offline   Reply With Quote
Old 01-12-2019, 09:17 PM   #2
Aqualight, wondering if you have any other information about the trim piece on your fridge? I have the same issue and would like to repair asap. I'm concerned that the refrigerator door is going to pop open when traveling.
RockyRoo19 is online now   Reply With Quote
Old 01-13-2019, 09:51 PM   #3
Aqualight's Avatar
I have searched everywhere and canít find anything on this trim piece. I left a message with local service center and havenít heard back yet. Iím also worried that the door will open while traveling. Iíll keep you posted.
Old 02-27-2019, 12:58 PM   #4
Null's Avatar
Mine just broke yesterday and I am also having trouble finding a replacement. However, while examining the part, it occurred to me that the right and left trim pieces appear identical and I should be able to swap them (until it breaks again ).
2015 Rockwood Signature 8329SS
2015 F-250 XLT 6.2 gas
Null is offline   Reply With Quote
Old 02-27-2019, 02:04 PM   #5
Null's Avatar
I just heard back from Dometic. My fridge is a DMR702 with a product number of 936000768 (there is a sticker inside the fridge).
The trim part is 3851516017 "front frame profile" and is the same part for both the right or left side. This is the trim piece with the plastic lip that the door latch catches on. Google searches for that part are coming up empty so I'll have to try ordering one from my RV dealer.
Old 02-27-2019, 04:43 PM   #6
Null's Avatar
Okay, so Dometic sent me a DMR702LB parts manual, which is what I posted above. In working with my dealer, they have a current DMR702 manual which indicates the trim piece is part number 385151601.
Both the DMR702 and DMR702LB have the same product number, so I'm not sure what, if any, difference there is in the two trim part numbers. Color perhaps?
Old 02-27-2019, 06:54 PM   #7
Great. Thanks for the update. Did you order a trim piece? Looks like you have 2 numbers for the same part.
Sent from my Nexus 7 using Forest River Forums mobile app
Old 03-01-2019, 04:50 PM   #8
Aqualight's Avatar
Thank you so much for the info! Iíll see if I can order through my dealer.
Old 03-26-2019, 05:55 PM   #9
Wondering if you have ordered the trim piece and cost?
dometic, fridge, gas
