Old 07-12-2019, 09:24 AM   #1
Dometic Fridge door latch problem
Just got back from a trip and noticed the door for the fridge had opened on our Rockwood 2906WS. It appears that the only thing that holds the door shut is a slight ridge in the plastic molding that runs the whole side of the fridge. Evidently the ridge broke off right where the latch on the door would normally catch. This probably happened due to opening the door by pulling on it like a home fridge instead of lifting the handle to unlatch. Any suggestions on how to fix this other than a new trailer?
jbrobson is offline   Reply With Quote
Old 07-13-2019, 06:46 AM   #2
Herk7769's Avatar
I would call Dometic Customer Service and see if you can buy the part, or direct you to a service place close by. (There are more than just dealerships)
I found out a radiator repair place around the corner was a certified Dometic repair location and they ordered a part I needed under warranty and let me install it myself.
HAM CALLSIGN - KC3FFW
Old 07-14-2019, 06:06 AM   #3
Dometic Door latch
We had the same issue on our Rockwood 8329SS. I found I was able to slide the piece of plastic moulding off and flip it around so that the part that used to be on the bottom was now up top where it latches. Works perfectly, and I figure if it happens again at some point I can simply take the piece from the other side. Hope that helps!
2015 Rockwood 8329SS
2017 Ram Limited Ecodiesel, 3.55 Axle ratio
Equalizer hitch
Breimert is offline   Reply With Quote
dometic, door, fridge
