Old 05-15-2015, 03:56 PM   #11
vinmaker's Avatar
You can also simply drill a hole in the floor and drain it out the bottom. FR engineers and qualified builders do that on the pop-ups that they build.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 05-17-2015, 07:55 AM   #12
VinceU's Avatar
Maybe not so good, the condensate can find It's way through the coating in the. bottom of the refer space, causing delay of the wall and bubbling in outside fiberglass.
VinceU is online now   Reply With Quote
Old 05-17-2015, 08:01 AM   #13
I like the way Norcold does it, just drain it into a small tray above the burner. Don't have to drill holes in the floor or thread it thru the vents on the access door.
Old 05-17-2015, 08:12 AM   #14
Canadian Member
itat's Avatar
4Sailrguy, if you're asking about the little plug, it should be in the end of the hose. It's there to prevent bugs from getting in the hose.
The hose should be routed through the grill far enough that when it drips it won't run down the wall.
The hose is very thin and can get brittle over time. If you have to replace it, use something more robust.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 05-17-2015, 08:16 AM   #15
The hose should also be routed such that it forms a P trap and then routed thru a top vent hole in the access door. The P trap is to prevent outside air from entering the refrigerator compartment.
Old 05-17-2015, 08:51 AM   #16
Canadian Member
itat's Avatar
OC, my previous camper, a Roo, had a Dometic fridge and the hose was no where near long enough to form a P trap and still be able to put it out through the access door. Of course, when I bought it used the hose was already brittle so the previous owner may have broken off some of it.
Do the drain hoses in Nocorlds have a P trap? I didn't notice one in my current TT.
Old 05-17-2015, 09:04 AM   #17
No, but it is only a 1/4" hose with a plug in the end and a shielded 3/32"dia hole in it. Not much air can get thru it.
dometic, drain, fridge
