Old 05-15-2015, 12:09 PM   #1
Sailrguy
Dometic fridge drain
Noticed in the panel behind the fridge there is a hose ( I assume drain) with an obvious factory plug fitted . Should be in or out?
Also, I noticed a posting awhile ago showing a small fan setup inside the fridge.
figure important for air circulation. Can someone advise where I can find that posting.
Tks
Sailrguy
4Sailrguy is offline   Reply With Quote
Old 05-15-2015, 12:14 PM   #2
TURBS's Avatar
Out
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "4 nights"
Old 05-15-2015, 12:16 PM   #3
The drain should come out the fridge grill. If you get frost,or condensation on the fins in your fridge the the water drains out that hose when it defrosts.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 05-15-2015, 02:17 PM   #4
checca's Avatar
Tks
Sailrguy
Drain tube.
2013 Lacrosse 318bhs
2010 Toyota Tundra Crew max 5.7 flex fuel / Installed airlift ultimate 5000 air bags and smart lift automatic leveling system.
Yamaha EF2000iS 2000 Watt Inverter Generators
Minooka, IL.
checca is offline   Reply With Quote
Old 05-15-2015, 02:50 PM   #5
Tks
Sailrguy
Look at the Post (It lasted 7 Years)! Your info will be in there! Youroo!!
Old 05-15-2015, 03:00 PM   #6
trbomax's Avatar
I looked for the drain and all I have is a 3/8" white hose that drops down into an aluminum pan situated directly under the boiler.So,whats with that?
trbomax is offline   Reply With Quote
Old 05-15-2015, 03:04 PM   #7
You probably have a Norcold, that's the way mine is also except mine is a little plastic tray.
Old 05-15-2015, 03:26 PM   #8
trbomax's Avatar
OK,that would explain that. I cant look at it now since its 300 miles south,but thanks.
Old 05-15-2015, 03:37 PM   #9
My tray is directly above and to the side of the burner.
Old 05-15-2015, 03:55 PM   #10
VinceU's Avatar
Tks
Sailrguy
It should be perforated with small holes, had two like that. Some used small fan esp when box is full, helps move cooler air.
dometic, drain, fridge
