Old 07-19-2014, 06:47 PM   #1
Lynkage's Avatar
Dometic fridge getting to cold
Anyone can tell me why? I keep moving the slide adjustable piece down but it keeps freezing stuff. It is getting to 20-25 degrees. The adjuster is now hanging down about halfway as long past the bottom fin.
I am running on electric. Outside temp is 75.
Sorry if this has been answered but I can't seem to get the fr app to search.
Is possibly the decal in the fridge wrong and I am supposed to move it up instead?
Thanks in advance for any help.
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 07-19-2014, 06:55 PM   #2
cat1956's Avatar
I would have to think you have a bad thermistor.Slinding down should make it warmer. If mine every goes bad I will replace with a Dometic snip the tip thermistor. You only have to change the thermistor and not the wire.
http://www.snip-the-tip.com/index.html
Tommy and Wanda
2014 Flagstaff 27RLWS
2017 Ram 1500 5.7 Hemi
Equal-i-zer 1,200/12,000 Weight Distribution w/ 4-Point Sway Control
cat1956 is offline   Reply With Quote
Old 07-19-2014, 07:39 PM   #3
Plain Old Member
We added the snip the tip deal to our forester fridge, and it worked quite well. Easy, quick and cheap mod.
As for what you have, you can also move it to another fin. Maybe a couple to the left. I'm not sure how long you're waiting to check temps, but it does take quite a while to adjust, as in hours.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 07-19-2014, 08:16 PM   #4
dcheatwood's Avatar
Try laying the thermistor out in the first rack. The lower it is in the frig, the warmer the frig should be. Your label is correct.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 07-19-2014, 08:48 PM   #5
Lynkage's Avatar
Thanks Guys!!
I have moved the thermistor out on the second rack. It was down behind the veggie drawers.
I have also moved the adjuster to a new fin. It was on the last one, moved to the second from the last.
We have been trying different positions since last night and all day. Checking intervals about 4-6 hours.
We shall see. I may need to order one of those other thermistors.
Shane & Antoinette
Old 07-20-2014, 05:37 AM   #6
fonzie's Avatar
here is a thread with similar issue...
Fridge Thermister Replacement
Fonzie
Old 07-20-2014, 11:54 AM   #7
Same problem froze everything solid - bad thermister - get this
Dometic Thermistor Repair Kit
cadman99 is offline   Reply With Quote
Old 07-20-2014, 02:01 PM   #8
dcheatwood's Avatar
Originally Posted by Lynkage View Post
Thanks Guys!!
Are you saying the end of the white wire was down behind the trays instead of in the clip attached to the fins at the top?
Old 07-20-2014, 10:36 PM   #9
Lynkage's Avatar
Yes
I did not know that was where it should be. Maybe it is trying to get it colder because it thinks it is not cold enough?
Shane & Antoinette
Old 07-21-2014, 12:13 AM   #10
Lynkage's Avatar
Moved it to the clip and now it is not cold enough so an moving the slide up. We will check it in the morning.
Thanks for the help.
Shane & Antoinette
dometic, fridge
