Old 06-02-2016, 08:34 AM   #11
Mr Havercamp's Avatar
Originally Posted by texasbuckeye View Post
On my "smoke stack" about a foot or a little higher from the floor was a reset button. Us till than, I had no 12vdc power to the refrigerator, so the power board was dead and 110vac or propane would not work. I had to reach up a bit with my hand to find the switch, push it in and magic ! !
That's a thermal fuse and it kicks off if the chimney overheats for some reason. If you reset it and it kicks off again you have something else going on and whatever it is its not good. Burner producing too much heat, blocked airflow or chimney/flue etc. Don't take chances if that thermal fuse keeps popping.
Mr Havercamp is offline   Reply With Quote
Old 06-02-2016, 09:48 AM   #12
Originally Posted by TURBS View Post
Yes
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "6"
I looked this morning but I couldn't find any reset button. Guess I'll be taking it to the dealer.
mattp160 is offline   Reply With Quote
Old 06-02-2016, 10:07 AM   #13
TURBS's Avatar
2015 Columbus 320RS
2008 2500HD Duramax
Old 06-02-2016, 10:08 AM   #14
Head Rambler
Did you actually test the fuses or just visually inspect them?
If you didn't test them with a meter, I'd do that before anything else.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 06-02-2016, 11:31 AM   #15
I tested them.
Old 06-02-2016, 11:32 AM   #16
2015 Columbus 320RS
2008 2500HD Duramax
thanks for the pic. I didn't notice a reset button on mine. I looked at that this morning. I also didn't see a fuse on that red wire. I guess I'll check that out before I drag it into the dealer.
To me this all seems like a fuse blown somewhere.
Old 06-02-2016, 11:36 AM   #17
dcheatwood's Avatar
I had same issue last week. It was the vertical fuse behind cover, lower left. It did not look blown.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
dcheatwood is online now   Reply With Quote
Old 06-02-2016, 11:40 AM   #18
You need to download the correct manuals and service documentation from Dometic for your exact model. Some do not have a reset on the thermal fuse and some do not have a separate thermal fuse controlled by the switch in Turb's picture such as this.
In this model the thermofuse is one assembly and it has no reset.
Needless to say, if your having issues with thermo fuses no matter where they are located that's a more critical issue than if the fridge is not cooling because you're playing with fire............literally.
2017 Roo 23WS
2015 GMC Sierra 2500HD
Old 06-02-2016, 11:51 AM   #19
I tested both fuses with a digital multimeter. Both fuses gave a tone indicating that they had connectivity between the two end.
Old 06-02-2016, 02:27 PM   #20
dcheatwood's Avatar
Bummer. Hope you get it figured out.
dometic, fridge, power
