Old 07-08-2016, 03:28 PM   #21
GSW
I have plugged the fridge 120v plug directly into an extension cord.
GSW is offline   Reply With Quote
Old 07-08-2016, 03:51 PM   #22
Head Rambler
How have you decided that it's not working on 120 volts? because the burner flame is still on?
Do the lights look right for it to be in Auto?
Do the buttons 'feel' right when pressing them?
There was a thread a few days ago that had about the same symptoms and they found the button board wasn't making contact when pressing the buttons.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 07-08-2016, 04:59 PM   #23
GSW
When I turn it on...press Auto, nothing happens for a few seconds then it tries to ignite the propane (which I have turned off)
Also, I get no 120v 0n the pins to the heater.
Old 07-08-2016, 05:02 PM   #24
GSW
All lights are ok. It works fine on propane....I have been using the propane part of it for months. It quit on 120v many months ago....I am just getting around to trying to fix it now.
Old 07-08-2016, 05:59 PM   #25
Head Rambler
It sounds like it thinks it doesn't have 120 volts to the unit. I'd check the button panel continuity just to be sure that isn't it.
You have 120 volts to all the proper places on the board, right? Except the element terminals of course.
Gotta go campin!
Old 07-08-2016, 06:16 PM   #26
northstar1960's Avatar
Wouldn't be the first time there was a loose connection in the eyebrow board . i would pull that and make sure all connections are made . if you have ac volts , fuse is good , heating element is good ,then it's either wiring or the lower circuit board .
northstar1960 is offline   Reply With Quote
Old 07-11-2016, 02:38 PM   #27
Cajun Style's Avatar
Check the GFI in the bathroom it might be tripped!
Harry-O
Cajun Style is offline   Reply With Quote
Old 07-11-2016, 03:14 PM   #28
GSW
Thanks for the input but I have plugged the fridge into an extension cord directly into the house.....and I read 120 v on the PWC input terminals.
dometic, fridge
