Old 06-28-2016, 03:04 PM   #1
GSW
Dometic fridge not working on 120 volts
My Dometic fridge does not work on 120v. ok on propane DM2852RBFX
120 volts read at J5 & J6. All fuses ok. No 120 v at J7 & J8. Replaced card 50-965201-E...still does not work.
Does heater element have to be plugged in to J7 and J8 to read 120v at those terminals?
Any ideas would be appreciated.
Gordon
GSW is offline   Reply With Quote
Old 06-28-2016, 03:34 PM   #2
Looking at the schematic, I don't think you'll read 120v between pins J7 & J8.
You'll probably need to read voltage between J7 and ground -or- J8 and ground.
J7 & J8 are where the 120v element plugs onto the board and appears to be the same line at that point. I assume it goes to ground inside the control board somewhere to turn it on and off.
Also, does the heating element have continuity/resistance?
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
Days Camped: '15=22 '16=46 '17=8
Old 06-28-2016, 03:44 PM   #3
GSW
I forgot to mention that when I turn on the fridge 120v should appear at terminals J7 & J8...based on the trouble shooting guide. I have also bought a new heating element..still not working.
Old 06-29-2016, 02:20 PM   #4
Head Rambler
When you turn the fridge on, and put it in Auto, and it sees 120 volts on J5 & J6, and it's calling for cool, it should have 120 volts on J7 & J8. I'm not sure if the board looks for continuity thru the element, but I suspect that it doesn't.
Did you replace the board with a Dometic part or the Dinosaur board?
Also, did you test the fuses with a meter? If not they could be blown and not look like it.
Gotta go campin!
Old 06-29-2016, 02:38 PM   #5
Exlimey's Avatar
My brand new Flagstaff 29KSWS with the Dometic refrigerator didn't work on 120 vac when we went out on my first trip. I got the flashing error code. I was ready to haul it down to my dealer for repairs after checking fuses which were ok. I decided to pop the cover off on the outside access before I committed to the 150 mile round trip. What I found was that the AC power was never plugged into the outlet. Needless to say I was upset after paying for the initial setup and almost making the long trip. Their service department got a piece of my mind. It may not be your problem, but sometimes it's the easy fix.
Neil and Kimberli
2016 Silverado Z71 double cab
2016 Flagstaff 29KSWS Super Lite
Nights camped 2016 - 27
Nights camped 2017 - 41
Exlimey is online now   Reply With Quote
Old 06-29-2016, 02:45 PM   #6
GSW
Replacement board is Dometic. Checked fuses with a meter..all ok.
Old 06-29-2016, 02:59 PM   #7
Head Rambler
So you replaced the board and the heater element and you're still not getting 120 volts between J7 & J8?
Check between J5 & J7 to see if you get 120 volts. That'll tell you if the neutral is good thru J7. Then check between J6 & J8.
Report back what you find.
Gotta go campin!
Old 06-29-2016, 05:15 PM   #8
GSW
120v between j5 and j7. 120v between both sides of 5 amp fuse to j6 and j7
Nothing between j7 and j8 or j6 and j8. looks like neutral is good but hot side not being closed between 5 amp fuse and j8....relay not activated?
Old 06-30-2016, 03:15 PM   #9
Head Rambler
That's what it's looking like. Is the relay integral to the board that you replaced, or is it separate?
Gotta go campin!
Old 06-30-2016, 04:54 PM   #10
GSW
Relay is PWC mounted.
dometic, fridge
