Was your battery cut off switch on?
The refrigerator wont operate on propane without 12v.
Even if the cut off switch was on... depending on how long the battery was not being charged by the converter it might have went dead from the parasitic drains.
If all that was OK... Some refrigerators will indicate if they tried to light on propane(usually three times) but was not able to. (gas valve not on, empty bottle)
Did you notice a fault indication? You didn't specify your model number so we're just throwing things out.
