Old 12-23-2013, 12:25 PM   #1
God Is Good
Dave8062's Avatar
Dometic Fridge short! Power Converter over charging?
Hi my name is Dave, I own a 2013 Flagstaff v-lite wfkss 35ft Diamond package. I have been having troubles with my dometic frigerator. found the problem to be the switch door switch, which also has a heater wire connected. I un plug the wire from the board and it works fine. I was told to check the converter, for AC not DC power, by checking the terminals on the battery with my multi meter. it shows 29 .the technician told me that that is way too high. where is the converter located on my camper?
Dave8062 is offline   Reply With Quote
Old 12-23-2013, 12:28 PM   #2
God Is Good
Dave8062's Avatar
all my lights and everything in the camper are working fine. I have been hooked up the shore power for about 4 months.battery shows 13.8 volts when I hooked up the shore power for DC.when I unhook shore power it shows 13.8 still.
Old 12-23-2013, 01:15 PM   #3
RKR
RKR's Avatar
Not familiar with your trailer. Hopefully somebody who is will chime in. If not, you should be able to trace the cables from your battery or relay back to your inverter ?
RKR is offline   Reply With Quote
Old 12-23-2013, 01:30 PM   #4
Witch Doctor's Avatar
Dave, I have a rockwood same family, just about all the converts are located at floor level, you have a black cover over it you should see a colored see thur area, press that in and the top half of the door opens, mine is at the door on the right, yours could be there or in that area or look around the refrigerator or at the bottoms of your cabinets.
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-23-2013, 01:36 PM   #5
TURBS's Avatar
Your looking for this.
The converter is at the bottom normally.
But sometimes its behind this unit on the floor.
Third picture shows converter removed.
TURBS
posted via my troll-mobile hand held type device.
ID:	44098   Click image for larger version
Old 12-23-2013, 01:38 PM   #6
If you are getting 13.8 unplugged you are overcharging your battery. You should have a WFCO converter 3 stage. it will charge at 14.4 then absorption at 13.6 (when you use your 12v) float is at 13.2, but you can not have any current draw for 21 hrs for it to drop 13.2. You might have a bad convertor. Also check your water in the battery....
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-23-2013, 01:40 PM   #7
Denver, CO
garbonz's Avatar
Is it 29 or 13.8? It can't be both and doesn't sound like the converter to me. Sound like a switch or control board problem. If the converter is providing 13.8 then it is working ok, but you may want to check the water in your batts.
2017 Fuse 23T
Old 12-23-2013, 01:45 PM   #8
Denver, CO
garbonz's Avatar
Correction, it should be 14.4 bulk at max amps, 14.4 absorbtion at decreasing amps till about 2 amps, or so and the float at 12.3 or so. The 13.8 is typical of many float chargers, but a bit high I agree and will most likely bubble the water out over time.
Still do not see how that could affect the refrigerator tho, it still sounds like a switch or control board on the frig to me.
2017 Fuse 23T
Old 12-23-2013, 01:59 PM   #9
Denver, CO
garbonz's Avatar
Nope, me wrong, your right at least for the current WFCO units although that charging process will leave the batteries well below their capacity
Output Ranges:- Nominal (Absorption Mode) 13.6 Vdc (includes charging and load)
- Boost (Bulk Mode) 14.4 Vdc
- Trickle (Float Mode) 13.2 Vdc (after 48 hrs.)
That, hoever still does not explain the OP's problem IMO.
A proper charging algorithm for the ABS portion for flooded cells should be more like 14.4 v until the charging amps drop pretty low (usually a couple hours). It makes no sense to expect 13.6 volts to do anything after the bulk charge.
To much information, probably, but there it is.
2017 Fuse 23T
Old 12-23-2013, 02:25 PM   #10
God Is Good
Dave8062's Avatar
Ok thanks. Well the Dometis guy had me check at the battery with my multi meter by putting the multi meter on AC-V on that it measured 29 hooked to shore power. When you check it for DC it is 13.8 without shore power still 13.8 DC. He said there is a so called reverb back from the converter. This all started when my fridfe lights started blinking back and forth when I shut or open the door. I changed out tge board after a rv tech checked all power coming and going and all was good. But that still never fixed it. When I took the far left wire that goes to the switch off it now works. The light starts dim and tgen glows bright and fridge works good and gas. But when I hook the wire up then the lights flicker and fridge will not work on gas or electric. All you here is clicking at tge board relay switch
