Old 06-20-2016, 08:09 PM   #91
TURBS's Avatar
Have you tried putting paper on lower vent to see if youve got enough flow to hold it?
How many cfm is the fans?
Can you feel hot air coming out of upper vent?
Sent from my SCH-R530U using Tapatalk
Old 06-20-2016, 09:54 PM   #92
When I say unit. I mean the whole camper.
KBUZ is offline   Reply With Quote
Old 06-20-2016, 10:04 PM   #93
Did not do paper test. As far as cfm. I'll check tomorrow. I forget. Heat coming out top yes. I had bug screens on the vents. I took them off, just to see if that restricted flow some. I did not turn the fans on inside the fridge. I had 40 degrees tops. So I thought I would turn them on. Heres the disturbing part. It went up to 48. I shut them off for curiosity. Half hour later it went back to 40.
Old 06-20-2016, 10:12 PM   #94
I know the the upper fan is 120 x120. cfms?
Old 06-20-2016, 10:16 PM   #95
When I ordered it it was to be 80x80 58 cfm. When it came it was 120x120 cfms again ????
Old 06-20-2016, 10:25 PM   #96
As of 10:20 pm EST. My probe (controller)says. 132. The thermister was about 2/3 up the slider clip. I put it at the top. Now is as high as it can go!!
Old 06-20-2016, 10:27 PM   #97
Fans are set to shut off at 130
Old 06-20-2016, 10:33 PM   #98
TURBS's Avatar
Lol
Old 06-21-2016, 07:37 AM   #99
The insulation on the sides of the fridge.... doesn't cover the sides of the cabinet. Wonder if I should replace with foam board and run it all the way to the exterior wall. Not to help the fridge as much as insulate inside rig from heat.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 06-22-2016, 04:41 PM   #100
I will be pulling my fridge this weekend. I wonder if someone left a space above the fridge. I read that traps heat. Back of fridge should be vertical all the way up.
dometic, fridge
