Old 06-25-2016, 09:51 AM   #101
Just pulled fridge. There should be zero clearance around fridge and no air space above it, to create the chimney effect in the back. The top plywood is not far enough back nor low enough.
The fan from factory is a 50 CFM unit. I will be adding two 118 CFM units and Turbs controller.
ID:	112133   Click image for larger version
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 06-25-2016, 04:42 PM   #102
Used air duct mastic to seal box, used Roxul Safe N Sound above and both sides of fridge.
107 degrees behind fridge. Full sun on that side and it's 98 degrees outside.
Now just waiting for fridge to cool!
ID:	112185   Click image for larger version
ID:	112186   Click image for larger version
ID:	112187   Click image for larger version
Old 06-25-2016, 07:02 PM   #103
MacDR's Avatar
Turbs, I can see wiring in the 2 fans to increase the airflow..but why the controller? Why not just let them run constantly.
2013 Ram 2500 "Cummins"
2014 Columbus 340RK
Cherry Hill Park
9800 Cherry Hill Rd
College Park, MD **20740
June 19-24
2014 Columbus 340RK
Winterized until Fort Wilderness April 12-25 2017
MacDR is online now   Reply With Quote
Old 06-25-2016, 07:23 PM   #104
2014 Columbus 340RK
Cherry Hill Park
9800 Cherry Hill Rd
June 19-24
Never miss the chance to add neat gizmos!
Old 06-25-2016, 07:26 PM   #105
MacDR's Avatar
LOL .. Got my InkBird sitting at my Home ready for next weekend..It was just a thought .. Great answer..
2014 Columbus 340RK
Cherry Hill Park
9800 Cherry Hill Rd
June 19-24
2014 Columbus 340RK
Old 06-25-2016, 07:46 PM   #106
It was also nice to be able to monitor what the temp is in the chase. Mine was 107 after the new fans with 98 outside temp in full sun.
One tip, when you're programming it, exit the menu by hitting the power button or it won't save the settings.
I didn't get a picture of the sides of the box but I added Roxul to both sides front to back top to bottom. My frig is zero clearance on the sides and Roxul doesn't burn. Sides of my cabinets are cooler now.
Old 06-25-2016, 07:46 PM   #107
Sky&Scuba
kendive's Avatar
Love it... I am the same way.
2015 F150 3.5 EcoBoost Lariat FX4 502A 3.55 Gears Max Tow KO2 Tires
2017 Grand Design Imagine 2150 RB / Traded in Catalina 253RKS
kendive is offline   Reply With Quote
Old 06-25-2016, 08:00 PM   #108
MacDR's Avatar
Thanks for the tip on the controller.. What temperature are you having it turning fans on ? I imagine the controller turns fan off under the same temperature..
2014 Columbus 340RK
Cherry Hill Park
9800 Cherry Hill Rd
June 19-24
2014 Columbus 340RK
Old 06-25-2016, 08:29 PM   #109
2014 Columbus 340RK
Cherry Hill Park
9800 Cherry Hill Rd
June 19-24
It's set for 70 right now but that's to play around with it. Haven't decided yet where to leave it.
The way it sets is that you set your temp, then you set how many degrees (+5, +10, etc) above (or below if using the heat relay) and then it runs until your originally set temp.
Gonna watch fridge Temps and see what the corresponding chase temp is and go from there.
Old 06-25-2016, 08:32 PM   #110
MacDR's Avatar
Thanks..ill keep checking the post and reply to what I find.. Ill be about 2 weeks behind you and will also post my findings.
2014 Columbus 340RK
Cherry Hill Park
9800 Cherry Hill Rd
June 19-24
2014 Columbus 340RK
dometic, fridge
