Old 06-28-2016, 08:12 AM   #121
TURBS's Avatar
Mine was 22 this am
Sent from my SCH-R530U using Tapatalk
Old 06-28-2016, 12:06 PM   #122
Originally Posted by TURBS View Post
Mine was 22 this am
Rub it in...
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 06-28-2016, 12:17 PM   #123
TURBS's Avatar
Originally Posted by Paul GA View Post
Rub it in...
Old 06-28-2016, 01:09 PM   #124
It's 43 right now at 1pm
Dinosaur Thermosistor Adjuster on its way
Old 06-28-2016, 01:19 PM   #125
northstar1960's Avatar
the fans are great when the heat is on but you may have other issues thermiistor could be bad or just giving false readings . also it could be a bad cooling unit even though you had no leaks it could be bad from factory and was not charged correctly . happens when all else fails then you need to look outside the box . my firdge keeps everthing very cold weather it's 95 or 35 out
northstar1960 is offline   Reply With Quote
Old 06-30-2016, 02:22 PM   #126
Bilcin's Avatar
Did they damage something?
Camping this weekend and at a loss here. Despiration really. Got another 120mm fan 100CFM should be here tomorrow. Gonna try pointing it at the canister.
I am beginning to think that the dealer let the cooling unit get too hot while diagnosing the problem, if that is a possibility?
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is online now   Reply With Quote
Old 06-30-2016, 03:09 PM   #127
TURBS's Avatar
No
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "10"
Old 06-30-2016, 03:22 PM   #128
Bilcin's Avatar
No
2015 Columbus 320RS
2008 2500HD Duramax
The cooling unit handles both refrigerator and freezer, correct? My freezer works, freezes a gallon of water, but refrigerator will not go below 42 degrees. 2 fans in the rear. Freezer works on both gas and electric, refrigerator neither. The only other possibility would be the Thermistor? ??
DOMETIC DM2652
Philadelphia PA
Old 06-30-2016, 07:42 PM   #129
DOMETIC DM2652
There could be a problem with the way the cooling unit was installed at the factory . the cooling tube for the RF may not be set well and they may have skipped out on the cooling /heat transfer gunk they use . so tired now i can't think what they call it . seems some people have this issue and they could have had a bad run of units that did not get assembled well . and it can't get diaged because everything seems to work fine but the fridge . did a unit last week like that . no reason to the fridge not to get cold but ??? adding more cooling fans won't help and may make it worse . if the freezer was nor freezing then maybe more fans . but this is another issue all together just not sure exactly what
Old 06-30-2016, 09:49 PM   #130
Bilcin's Avatar
Wow, more fans could make it worse! !!! Didn't expect that!!! I do know that the tube that runs up the refrigerator to the top where the cooling fins are is HOT. Accidentally touched the back of my wrist on it and burned my skin resulting in a blister, thought an extra fan would help cool it down. What a complicated system this is!
Philadelphia PA
dometic, fridge
