Old 05-27-2016, 08:41 AM   #11
TURBS's Avatar
Originally Posted by KBUZ View Post
Yes, that's what I have been reading. Turbs, The first photo. Is that blowing in or out? Which is better?
Blowing out, that's the top fan.
At the bottom I have one drawing air in.
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "5"
2015 nights camped "34"
Old 05-27-2016, 12:16 PM   #12
No settings on ours. There is a sensor, or prob (?) attached to the cooling fin inside the fridge. I slid it up from the bottom to the center and that seems to have made a difference.
How to adjust the temperature would be a most welcome addition to the limited information in the owners manual !
Denny B is offline   Reply With Quote
Old 05-27-2016, 12:42 PM   #13
TURBS's Avatar
Up is colder down is warmer
2008 2500hd Duramax
2015 Columbus 320RS
Old 05-27-2016, 01:35 PM   #14
Turbs. How did you wire the fans? 120v? 12v? hotwired somehow? switches? THANK YOU SO MUCH WITH INFO NOW AND FUTURE!!!!! Headed out now. will check when I get back.
KBUZ is offline   Reply With Quote
Old 05-27-2016, 02:08 PM   #15
TURBS's Avatar
Dometic fridge wide temp swings
I installed both a 120 fan and a 12v fan.
They are both ran by temp controllers as you can see at the top of this pic.
I hadn't mounted the 12v fan or the temp controller yet.
The 120v plugs right in where the fridge plugs in.
The 12v fan is wired in to the switched power of the 12v side of the fridge.
I'll try to get some pics this weekend.
Both fans are 120mm
Right now the temp controllers are set to come on at 103 and go off at 95
2008 2500hd Duramax
2015 Columbus 320RS
Old 05-27-2016, 06:10 PM   #16
Thank you. It would be advantageous for Dometic to state that in the manual.
Old 05-27-2016, 06:17 PM   #17
TURBS's Avatar
They do
2008 2500hd Duramax
2015 Columbus 320RS
Old 05-27-2016, 06:38 PM   #18
I just took another look at the manual that I have an could find no reference to adjusting the temperature.
Old 05-28-2016, 12:28 AM   #19
MNtraveler's Avatar
Our manual (2652 and other models) doesn't cover it either. In fact, it states that the temperature is factory set which implies non-adjustable. However, the in-refer slider is labeled nicely.
Name:	ImageUploadedByForest River Forums1464409681.718931.jpg
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 05-28-2016, 11:00 AM   #20
MNtraveler's Avatar
Temp slider label.
Name:	ImageUploadedByForest River Forums1464447585.922959.jpg
2016 Forester 2401R
dometic, fridge
