Old 06-02-2016, 09:32 AM   #31
Flybob's Avatar
The gas-absorption refrigerators used in RVs are much less efficient at cooling than your home fridge so their recovery time is slower. In addition, the ability to absorb heat energy introduced when the door is opened is very dependent on the contents. If the fridge is fairly full a considerable amount of heat can be absorbed there by keeping the temp fairly stable. If the fridge is mostly empty, there is little ability to absorb heat. If you are having difficulty keeping the temp stable, try keeping fridge full and open time to a min. A fan in the outside compartment to assist on removing heat from the coils is also a big help.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 06-02-2016, 06:16 PM   #32
The day mine was giving problems the outside fan did not come on. The day before and day after it did. I can't find the thermostat for the fan. I see it on the wiring schematic but I can't see it.
Also, wonder if the plastic shelf covers and fin cover is making things worse.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 06-02-2016, 08:19 PM   #33
TURBS's Avatar
Thermostat "snap disc" is up top in the upper cover if you have one.
It's on the far right screwed to one of the cooling fins.
The stock fans are junk I'd look into replacing it with a 120mm ball bearing fan.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "6"
Old 06-02-2016, 10:54 PM   #34
Do I have to unseal the roof to get access?
Old 06-03-2016, 06:47 AM   #35
TURBS's Avatar
If you have a rooftop vent you won't be able to acces it from the top.
I was referring to an in slide fridge with both vents in the slide wall.
2015 Columbus 320RS
2008 2500HD Duramax
Old 06-03-2016, 10:39 AM   #36
Pull the fridge then right?
Old 06-03-2016, 12:19 PM   #37
TURBS's Avatar
I'd have to say yes,
2015 Columbus 320RS
2008 2500HD Duramax
Old 06-03-2016, 01:37 PM   #38
Thank you for all the info Turbs!
Old 06-03-2016, 02:25 PM   #39
TURBS's Avatar
Paul, are going to try and replace your fan? Thermostat?
2015 Columbus 320RS
2008 2500HD Duramax
Old 06-03-2016, 09:26 PM   #40
2015 Columbus 320RS
2008 2500HD Duramax
I would like to see the thermostat... see if there is a better quality one or maybe it's poorly mounted... possibly wire in a manual override switch for it. It should have come on that middle day it was the same Temps inside and outside the camper all three days.
dometic, fridge
