Old 06-03-2016, 10:43 PM   #41
Turbs:
What are you using to turn the fans on and off? Is it that thing with the LED readout in your pic?
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 06-03-2016, 10:59 PM   #42
Bilcin's Avatar
Originally Posted by KBUZ View Post
Curious. Is your fridge located in a slide? Mine is. I think just not enough air flow behind. (reading other post too) Just spit balling here. When vented out the roof, I think the air escapes better. When going out the side though a vent. The heat roles around in the cavity at the top. I'm getting frost on the back of the inside of the freezer. thinking the air is pretty warm behind causing it to condensate and refreeze in the back. Back to your original post. I checked mine first thing this morning. 35 degrees. I know by this afternoon (heat of day) it will be back to 50. For this trip I told my wife. I'm putting some freezer bags of ice through out the fridge. hoping to help it along.
My Dometic 2652 fridge is also on a slide, same problem. Dometic advised Forrest River that a fan kit IS required on the refridge that is located on the slide, and had my dealer install a fan on the rear of refridge just below the upper vent. Well, freezer works and always did, however, frigdge hits 55+ This past weekend, put a small fan in the lower vent area, aimed it at a 45 degree angle so the airflow hits the cooling unit(black cylinder) and the radiator. Temp went from 55 to 34 in 3 hours with an outside temp 84. The cooling unit and radiator was warm, not hot to the touch. As soon as I took the fan away, temp shot up to 54 in less than an hour and the cooling unit and radiator were hot. This refridgertor/freezer set up requires the fans to aid in airflow. My previous trailer, 2652 fridge was not on a slide and worked perfectly.
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is offline   Reply With Quote
Old 06-04-2016, 04:45 AM   #43
TURBS's Avatar
Originally Posted by rockfordroo View Post
Turbs:
It's a digital fan controller.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "6"
Old 06-04-2016, 10:56 AM   #44
2015 Columbus 320RS
2008 2500HD Duramax
Can you provide make/model/price?
Old 06-04-2016, 11:02 AM   #45
TURBS's Avatar
Yes give me a little time today
2015 Columbus 320RS
2008 2500HD Duramax
Old 06-04-2016, 02:50 PM   #46
TURBS's Avatar
http://www.ebay.com/itm/141777090187...%3AMEBIDX%3AIT
Try this
2015 Columbus 320RS
2008 2500HD Duramax
Old 06-04-2016, 10:47 PM   #47
Thanks Turbs!
Old 06-04-2016, 10:58 PM   #48
Thermostat "snap disc" is up top in the upper cover if you have one.
It's on the far right screwed to one of the cooling fins.
The stock fans are junk I'd look into replacing it with a 120mm ball bearing fan.
2015 Columbus 320RS
2008 2500HD Duramax
Mine is screwed to one of the fins on the far left to be away from the chimney. It's easiest to just follow the wire from the fan to the thermostat.
I agree on the factory fan. Mine had fallen off before delivery and the dealer screwed up by reinstalling it using metal plumber strapping and wire ties to attach it to the coolant lines and fins. First thing I did when I saw what they had done was order a low noise 120mm ball bearing fan to replace the factory unit and then mount it correctly. Not only is the new fan quieter but has a better CFM than the one Dometic supplies to Forest River.
2015 F150 Ecoboost
2014 Palomini 142 CK
keith_h is offline   Reply With Quote
Old 06-05-2016, 02:09 AM   #49
HarrynSally's Avatar
Look at this on eBay http://www.ebay.com/itm/252386910825
Very quiet, works great and come with on and off switch and temp switch.
Also I put a snip-the-tip.com on mine and that problem resolved. And a vent fan inside I'll have to repost.
HarrynSally is offline   Reply With Quote
Old 06-05-2016, 02:14 AM   #50
Look at this on eBay http://www.ebay.com/itm/390661070734
Here's my repost, all three together works great cools quick !
dometic, fridge
