Old 06-05-2016, 10:35 AM   #51
I tried thermostatically controlled fans for the condenser, and while they work well, they didn't solve the problem. The Wildwood trailer I have has two exterior vents for the refrigerator one low and the other high. Even with the fans the grille over the top vent restricts condenser air flow so much that the refrigerator will not cool in warm weather. Removing the top grille when camping is ugly but it lets the heat out and solves the problem. It is also a quick and easy test to see if inadequate condenser air circulation is causing the reefer to work poorly.
Lefty665 is offline   Reply With Quote
Old 06-05-2016, 10:41 AM   #52
Flybob's Avatar
If the shelf covers are solid so as to limit air circulation, they will have some impact on temp stability as areas closer to the cooling fins will be cooler while areas further away can be warmer. An internal fan will help some.
Originally Posted by Paul GA View Post
Also, wonder if the plastic shelf covers and fin cover is making things worse.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 06-05-2016, 11:12 AM   #53
TURBS's Avatar
I have two vents in the sidewall slide and it cools fine .
On fan at the bottom one at the top.
My lower grill will hold a piece of paper to it with all the air flow.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "6"
Old 06-05-2016, 11:53 AM   #54
Glad you've got a better vent design than mine. Haven't tried the paper test, what are the current draw and cfm of the fan? Mine pull well with the top grille out, but block up pretty tight with the grill in. I'm using 12v 120mm and 140mm computer cooling fans that move roughly 40 and 60 cfm, draw about 1.2 and 1.7 watts respectively and are very quiet. With overlapping ranges on the thermostats they are light on the batteries when boondocking. Reducing grill impediments to airflow will be the answer for me. YMMV. Without airflow restrictions convection cooling as it was designed may well be enough. It's really sort of irritating to have to re-engineer something as straightforward as airflow over a refrigerator condenser.
Old 06-05-2016, 01:37 PM   #55
TURBS's Avatar
130 cfm upper 75 cfm lower both 120mm
2015 Columbus 320RS
2008 2500HD Duramax
Old 06-09-2016, 06:46 PM   #56
No pressure Turbs! Were you able to get more pictures of your wiring? I ordered some of the things you posted to use. Just curious on how you wired thing. My things are to come Monday. THANKS!!!!
KBUZ is offline   Reply With Quote
Old 06-09-2016, 07:38 PM   #57
TURBS's Avatar
I will tomorrow when I get home if ok?
89 degrees today!
Fridge at 28 degrees !
2015 Columbus 320RS
2008 2500HD Duramax
2016 nights camped "10"
Old 06-09-2016, 08:23 PM   #58
Thats fine! Be safe!!!!
Old 06-12-2016, 09:21 AM   #59
TURBS's Avatar
I'm getting pictures this morning.
2015 Columbus 320RS
2008 2500HD Duramax
Old 06-12-2016, 10:05 AM   #60
MacDR's Avatar
I'm going to glam onto those pictures also Turbs..
Thanks for proving the pictures.
2013 Ram 2500 "Cummins"
2014 Columbus 340RK
Cherry Hill Park
9800 Cherry Hill Rd
College Park, MD **20740
June 19-24
2014 Columbus 340RK
Winterized until Fort Wilderness April 12-25 2017
MacDR is offline   Reply With Quote
dometic, fridge
