Old 06-14-2016, 07:05 PM   #71
TURBS's Avatar
Originally Posted by KBUZ View Post
FUNNY! I watched a you tube video the other day. It was a dealership service dept. It was a Jayco FW. Looking at your pictures. The space above the fridge where your controllers are. They said, It is to have a deflector to exhaust the hot air out the vent. It is not suppose to be an open cavity. Mine is exactly like yours. (wheres our deflectors?) There's more to this video on the deflector issue. If you get a chance search it.
There is a curved deflector
Its above the fan controllers in my pictures.
Sent from my SCH-R530U using Tapatalk
Old 06-14-2016, 07:09 PM   #72
TURBS's Avatar
Fans will suck a piece of paper to the lower grill and hold it.
Hot air pours out from the top grill!
Old 06-14-2016, 08:33 PM   #73
No deflector in mine. Will be though! The video showed how and what they used.
KBUZ is offline   Reply With Quote
Old 06-14-2016, 08:53 PM   #74
Thanks Again TURBS! My controller should be coming tommorrow. The last piece of the puzzle. Hope to get right on this. Suppose to get pretty warm here. Best time to test it.
Old 06-14-2016, 09:26 PM   #75
Thanks for the pics, Turbs.
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
Old 06-14-2016, 09:27 PM   #76
TURBS's Avatar
No problem
Old 06-15-2016, 07:46 AM   #77
My deflector is a flat piece of sheet metal just above the top of the upper vent opening. It is didn't even go all of the way across the internal cavity. It was just the width of the opening. I picked up a roll of 10" aluminum flashing and covered the open areas to each side. I can't really say if it helped (gut says it does) but it did make the installation conform to the Dometic installation instructions.
2015 F150 Ecoboost
2014 Palomini 142 CK
keith_h is offline   Reply With Quote
Old 06-15-2016, 09:00 AM   #78
TURBS's Avatar
You can see the bottom of the deflector in this pic.
Old 06-16-2016, 06:42 AM   #79
TURBS.This maybe a ridiculous question, Is the controller on all the time? Does it have a on/ off on it? Only asking because, my instuctions are not exactly clear. Want to make sure before I wire it. Mine is 12v.
Old 06-16-2016, 07:02 AM   #80
TURBS's Avatar
12v controller is on all the time if you use the access point I showed.
There is a switched wire near the the controll board that will switch on and off with the fridge.
Eventually im going to install an on / off switch like I did in my previous camper.
The controller directions can be a touch confusing at first to program it but once you figure it out its not to difficult.
Right now im in testing mode as far as temp settings, thus far im at fans on at 105 degrees and fans off at 95 degrees.
They mostly run non stop during the day but keep the back of the fridge compartment @ a constant 100 degrees. "So far"
dometic, fridge
