06-12-2016, 10:06 AM
#61
Providing.. Dam autocorrect..[emoji13]
2013 Ram 2500 "Cummins"
2014 Columbus 340RK
Cherry Hill Park
9800 Cherry Hill Rd
College Park, MD **20740
June 19-24
2014 Columbus 340RK
Month of July in the Egg Harbor Campground, Door County, WI
5 stars
06-13-2016, 08:20 AM
#62
Ill get them posted up today.
Sent from my SCH-R530U using Tapatalk
06-14-2016, 06:28 AM
#63
We'll EVIDENTLY im having phone issues, pictures taken I'LL see if I can get them to post
06-14-2016, 07:01 AM
#64
I downloaded the new IPhone 10 beta software for IOS and Iwatch 3 beta software and the Beta Sierra Software for my Laptop..I'll be screwed up for today..[emoji41] take your time pally.. Not in a hurry.
2014 Columbus 340RK
Cherry Hill Park
9800 Cherry Hill Rd
June 19-24
2014 Columbus 340RK
5 stars
06-14-2016, 06:11 PM
#65
Here we go.
Lower fan.
Lower fan and controller 12v supply.
Upper fan.
Upper and lower fan controllers.
Upper and lower fan controller temp probes.
Factory fan thermostat.
06-14-2016, 06:20 PM
#66
Are there fuses on your 12v feed? If so before the controller? or After controller to fan?
06-14-2016, 06:35 PM
#67
FUNNY! I watched a you tube video the other day. It was a dealership service dept. It was a Jayco FW. Looking at your pictures. The space above the fridge where your controllers are. They said, It is to have a deflector to exhaust the hot air out the vent. It is not suppose to be an open cavity. Mine is exactly like yours. (wheres our deflectors?) There's more to this video on the deflector issue. If you get a chance search it.
06-14-2016, 06:39 PM
#68
Oh, thanks turb, for taking the time to take and post pictures!!!!!
06-14-2016, 07:01 PM
#69
Thank You so much.. Got them all.. Increasing the circulation has to help a lot.. Just need to confirm where you jumpered the wires.
2014 Columbus 340RK
Cherry Hill Park
9800 Cherry Hill Rd
June 19-24
2014 Columbus 340RK
5 stars
06-14-2016, 07:05 PM
#70
Sorry I didnt take pic of fuse, its a 2 amp ato in a holder between power source and fan controller.
#71
There is a curved deflector
Its above the fan controllers in my pictures.
06-14-2016, 07:09 PM
#72
Fans will suck a piece of paper to the lower grill and hold it.
Hot air pours out from the top grill!
06-14-2016, 08:33 PM
#73
No deflector in mine. Will be though! The video showed how and what they used.
06-14-2016, 08:53 PM
#74
Thanks Again TURBS! My controller should be coming tommorrow. The last piece of the puzzle. Hope to get right on this. Suppose to get pretty warm here. Best time to test it.
06-14-2016, 09:26 PM
#75
Thanks for the pics, Turbs.
2011 Traverse LT, 3.6L, FWD
06-14-2016, 09:27 PM
#76
No problem
06-15-2016, 07:46 AM
#77
My deflector is a flat piece of sheet metal just above the top of the upper vent opening. It is didn't even go all of the way across the internal cavity. It was just the width of the opening. I picked up a roll of 10" aluminum flashing and covered the open areas to each side. I can't really say if it helped (gut says it does) but it did make the installation conform to the Dometic installation instructions.
06-15-2016, 09:00 AM
#78
You can see the bottom of the deflector in this pic.
06-16-2016, 06:42 AM
#79
TURBS.This maybe a ridiculous question, Is the controller on all the time? Does it have a on/ off on it? Only asking because, my instuctions are not exactly clear. Want to make sure before I wire it. Mine is 12v.
06-16-2016, 07:02 AM
#80
12v controller is on all the time if you use the access point I showed.
There is a switched wire near the the controll board that will switch on and off with the fridge.
Eventually im going to install an on / off switch like I did in my previous camper.
The controller directions can be a touch confusing at first to program it but once you figure it out its not to difficult.
Right now im in testing mode as far as temp settings, thus far im at fans on at 105 degrees and fans off at 95 degrees.
They mostly run non stop during the day but keep the back of the fridge compartment @ a constant 100 degrees. "So far"
