Originally Posted by pcoole55
We bought a used 2005 Rockwood Forest River TT. It is not our first rv and not the first time our fridge has on/auto/gas. BUT it is the first time I came across the problem of it NOT Cooling and freezing ON ELECTRIC. It had power because the light worked and the small circulation fan that previous owner installed runs.
A few days after we got the TT my ac thermostat was not working...its on 12v. Got a repairman out and it was the converter that had died, it was only pushing like 3v.
But we put the fridge on, clicked auto and within a few minutes the CHECK light comes on. We have replaced fuses, checked the connections outside, checked fuse panel inside.
Are we just missing something? Do you have any idea what we need to do ...can not pay repariman this time
1) The black on/off switch is a "climate control" and is run off the battery power. It should be turned off when boondocking (no AC shore power) to extend battery life.
2) The check light means that the fridge is not getting 120 volt AC power AND/OR the gas will not light "for some reason" (normally no gas pressure if it has worked on gas before). If the GAS button is "OUT", it will not work on AC shore power even if it is available. Make sure it is "IN" to allow the AC shore power to work.
Make sure you have AT LEAST 12 volts of battery voltage AND the gas is on and you can run the range burners (good pressure).
IF still no light with good gas pressure and voltage; press the stack over-temperature fuse to make sure it has not opened. (You may need to remove the metal cover plate to get to it, but if you have skinny hands you should be able to get behind it without cutting yourself on the metal.)
Do not worry about the internal glass fuses unless you do not have 12 volts (lights on panel do not come on when in AUTO) or it works fine on gas but does not work on shore power ONLY.
