Old 10-26-2014, 08:49 AM   #1
Engineer of Crazy Train
ChooChooMan74's Avatar
Dometic Fridge - Won't Cool in Cool Weather
I noticed early this spring, and again this fall, that my dometic fridge won't cool during cool weather. All Summer, no issues. Anything I should look for or try? Unit is sitting within 1/2 bubble of level with a bubble level in the freezer.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 10-26-2014, 09:10 AM   #2
Is this on electric or gas?
keith_h is offline   Reply With Quote
Old 10-26-2014, 02:51 PM   #3
Either, but most recently electric. But I did try gas in the spring.
Locomotive Engineer
Old 10-27-2014, 09:45 AM   #4
I'm by no means an expert but since the refrigerator relies upon boiling a water/ammonia mixture I would expect the efficiency to drop somewhat when the unit is colder. I would also expect it to show up problems that can affect the heating elements such as a partially blocked flu or a weak electrical heater. Have you checked the flu and upper air vents for blockages? In general I would look for anything that results in less efficient heating of the ammonia mixture. After this I am out of my knowledge base and would refer it to someone who works with these things on a regular basis.
Old 10-27-2014, 03:05 PM   #5
I can see all the way up to the fans and beyond. I just turned it on gas to see what happens. I feel the burner side getting warm
Locomotive Engineer
Old 10-27-2014, 05:43 PM   #6
In very cold weather the liquid will not boil and operate the frig properly.
Usually at 32į and below. Block off the outside vents or find a way to heat the frig outer compartment a bit.
cadman99 is offline   Reply With Quote
Old 10-27-2014, 05:58 PM   #7
Thanks for the tip. It wasn't that cold, but in the 40s. I will try a few experiments
Locomotive Engineer
Old 10-27-2014, 06:41 PM   #8
DDC
DDC's Avatar
My DW complained last Feb. when we were getting set to head south that the fridge was not cooling, it was -22C outside at the time.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
dometic, fridge
