Old 05-28-2011, 07:20 PM   #1
Question Dometic Fridge Won't Operate
Dometic Model DM2652
Would the interior light in the fridge affect the fridge's operation? The light isn't on & I haven't been able to get the fridge to cool down. Neither the AUTO or CHECK lights come on when I attempt to start the fridge.
110 V is fine
breaker isn't tripped
15 A fuse is OK
propane is flowing to stove, furnace & water heater
trailer is level
GFCI has been tested & reset (caused an issue in my previous P/U)
The fridge was working fine in September on our last trip.
Anything else I should be looking for?
2017 Chevrolet K2500HD
2009 Rockwood 2106 Mini-Lite
https://inlinethumb45.webshots.com/3...600x600Q85.jpg
revrnd is offline   Reply With Quote
Old 05-28-2011, 07:54 PM   #2
onetonford's Avatar
Have you checked theses fuses.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 05-28-2011, 08:02 PM   #3
No I haven't. I did mange to ruin the "push rivets" that hold the exterior panel on. I won't be able to check them until Monday afternoon.
Thanks for the tip. I was just thinking of the fuses in the main elec' box.
Old 05-29-2011, 06:53 AM   #4
Have you checked the temperature sensor? Sometimes this becomes unattached from the plastic wire housing and will not call for cooler temps inside the fridge, thus the thermostat is satisfied due to the incorrect reading.
2011 Coachmen 292 bhds
2005 Silverado 5.3 L w/ 4:10 and Equal-i-zer
Eric, Heather and Elaine Higgs
TopGobbler is offline   Reply With Quote
Old 05-29-2011, 06:59 AM   #5
There is an inline fuse on a black wire near this box on a black wire also at the left of the black box. Have you checked it?
capucine is offline   Reply With Quote
