Old 04-14-2019, 08:18 AM   #1
Dometic Furnace won't kick off
I have a 2016 Forest River Lacrosse but the furnace has never been used. No propane to the RV before I bought it and the furnace won't work. No ticking noise like it's trying to light, no fan, nothing. Looked in the owners manual and it says dealer service only if pilot has never been lit. Is that right ?
Kdspott72 is offline   Reply With Quote
Old 04-14-2019, 04:05 PM   #2
ejohnson1144's Avatar
What kind of thermostat
ejohnson1144 is offline   Reply With Quote
Old 04-14-2019, 04:19 PM   #3
cavie's Avatar
Furnace does not have a pilot. It have an igniter like your BBQ grill powered by 12 volts. Check all the 12 volt fuses. Turn on you stove top and get a good flame going use all three burners. The try the furnace again.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 04-14-2019, 05:22 PM   #4
Thank you. I will try that directly. I do remember the girl I bought it from saying she "took a fuse out because the carbon monoxide detector would not quit beeping".
Kdspott72
Old 04-14-2019, 05:41 PM   #5
I replaced the 15V fuse (no 12V fuses) that she had removed and lit all three burners and nothing. When I put the thermostat on "Heat" and turn fan mode to "On" instead of "Auto" the air conditioner comes on. Smh
Kdspott72
Old 04-14-2019, 06:05 PM   #6
That is not the A/C running, it is just the fan blowing. If set to high or low it blows continuously. On Auto it cycles.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 04-14-2019, 06:21 PM   #7
cavie's Avatar
the correct language is 15 amp fuse and 12 volts. All you fuses are 12 volts. All your circuits breakers are 120 volts. It the amperage that changes.
Old 04-14-2019, 06:27 PM   #8
cavie's Avatar
Check your t-stat mode. you have turned on your heat pump. It is the same as A/C only in reverse. You need furnace mode. It is at floor level. Yes, the 15 amp fuse does a number of 12 volt circuits for multiply things. Fridge, Furnace, range hood etc.
Old 04-14-2019, 06:29 PM   #9
Oh okay. Well still no furnace and no clicking noises like it was trying to light.
Kdspott72
Old 04-14-2019, 06:34 PM   #10
Here's a service manual with troubleshooting info.
2011 Traverse LT, 3.6L, FWD
dometic, furnace
