Old 07-11-2016, 10:46 AM   #1
jbhodj's Avatar
Dometic Gas/Electric fridge ?
My Dometic has 2 switches, on off and auto/gas button. When hooked to shore power and on auto and gas turned off you can hear it trying to light the heater and then check light comes on. Turn on propane and purge, the turn off and back on the fridge lights burner although it's set to auto which I thought would not use any propane to run. Is this normal for the burner to light when running on electric? It will run with propane switch selected just fine with gas in but won't run in auto with gas off
jbhodj is offline   Reply With Quote
Old 07-11-2016, 12:09 PM   #2
TURBS's Avatar
Pull outside cover and make sure fridge is plugged in.
If it is plugged in check the circuit breaker in your distribution panel.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "14"
TURBS is online now   Reply With Quote
Old 07-11-2016, 12:14 PM   #3
Canadian Member
itat's Avatar
I agree with TURBS. It doesn't seem to be getting 120 VAC power. Although, I'd check them in the opposite order just because its easier to check the breaker.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer
2016 Ford F-250 XLT SuperCrew, 6.2L, 4x4, 6'9" bed, 3.73
Fondly remembered:
2009 Ford F-150 XLT SuperCrew, 5.4L, 4x4, 5'6" bed (2012 - 2016)
itat is online now   Reply With Quote
Old 07-11-2016, 12:22 PM   #4
TURBS's Avatar
I'd agree
2015 Columbus 320RS
2008 2500HD Duramax
Old 07-11-2016, 02:32 PM   #5
Cajun Style's Avatar
Check your GFI in the bathroom it might be tripped!
Harry-O
Cajun Style is online now   Reply With Quote
Old 07-11-2016, 09:07 PM   #6
jbhodj's Avatar
Power and GFI checked as well as breaker box. Checked power at plug and good there so may have panel issue I'm guessing or something else
Old 07-12-2016, 11:03 AM   #7
Head Rambler
There have been a couple of reports of the button (Eyebrow) board not making contact when the buttons are pressed, and the units staying on gas when Auto was selected.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 07-12-2016, 11:15 AM   #8
Flybob's Avatar
Check with the auto/gas button in other position.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-12-2016, 12:50 PM   #9
jbhodj's Avatar
Tried that and when propane is selected it runs on propane
Old 07-12-2016, 12:51 PM   #10
jbhodj's Avatar
When you say eyebrow what are you referring to?
dometic, electric, fridge, gas, select
