Old 07-18-2016, 07:45 PM   #1
RollingDownTheHighway's Avatar
Dometic gas/electric fridge stop running
On our week long trip and the fridge has stopped cooling, opened the freezer and the ice was water. It has power but not cooling at all. The plug has juice and I have plenty of propane, tried it on both and it won't kick on to start cooling.
I have the slide in the fridge slid up and it won't kick on
Thoughts ??
2013 Prime Time Tracer 3200BHT
2016 GMC Crew Cab Duramax All Terrain
Ribs in the smoker and Whiskey in hand
RollingDownTheHighway is offline   Reply With Quote
Old 07-18-2016, 08:07 PM   #2
SeaDog's Avatar
There is no kick on with this type of fridge its an absorption unit (no compressor like residential fridge) It takes hours to cool down. Make sure you have 12V power to the fridge and check to see if the propane lights, if so let it sit without opening for 24 hours and then see how cold it is. You can try the same thing if you are plugged into shore power in any case you need 12V to make it work.
Retired Navy
Jake my sidekick (yellow Lab)
2006 F350 6.0
2016 Flagstaff 26 FKWS
AF&AM of Idaho
SeaDog is online now   Reply With Quote
Old 07-19-2016, 12:14 PM   #3
Head Rambler
Since it won't work on either gas or electric, I'm thinking the same as SeaDog, check the 12 volt power to the board.
Also, there are a couple of fuses on the board and one of them could be blown.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 07-19-2016, 12:34 PM   #4
I got it working. I had to unplug it and reset then it finally started to cool down
Old 07-19-2016, 01:28 PM   #5
Head Rambler
Thanks for coming back and letting us know what the fix was.
Gotta go campin!
Old 07-19-2016, 07:35 PM   #6
BigMac
bmcilravey's Avatar
Reset?.
Good fix, like a computer. Unplug it and try again. But what do you mean by "Reset" ??
bmcilravey is offline   Reply With Quote
dometic, electric, fridge, gas, select
