Originally Posted by sgtsdj
What did you mount the two externals on? What did you wire them to?
The two externals were mounted to a filler plate that was removable.
I just cut two holes in it and screwed the fans to it.
Power came from the lower left of exterior fridge there's a cover there and a switched hot .
When u turn fridge on that junction is hot.
When fridge is off its cold.
I'll take pictures within the hour for you.
Turbs
