Old 09-06-2015, 09:20 PM   #1
GASPEDDLER's Avatar
Dometic not cooling
Okay guys I'm tired of troubleshooting this fridge and could use some help. My fridge type runs on both propane and electric and won't cool continuously on neither power source. I've had cooling issues on and off for the last month but would finally come down to temp and maintain 38 to 42...then again will go back up to 60's. I discovered the slider laying on the shelve last night and installed it back on the last fin to the highest (coldest) setting but as of 24 hours later still in the 60's. I realize it takes time to bounce back to proper temp but is there something I'm missing? The freezer seems fine and maintains ice cubes in a frozen state. Thank god I have my outside fridge to keep things fresh. Btw my TT is level. Any help would be appreciated.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 09-07-2015, 06:51 AM   #2
Unplug the thermistor and see if it cools then. If so, replace the thermistor. How old is the fridge. There are many videos on youtube.
harderd is offline   Reply With Quote
Old 09-07-2015, 07:52 AM   #3
GASPEDDLER's Avatar
Dometic not cooling
Yes, I watched all of those videos last night, all very informative. The fridge is original to my 2011 Puma. I ended up adjusting the thermistor probe to the top of the clip and set the clip at about 2/3s the distance from the bottom of the far right fin to top. This morning she's back down in the lower 40's. Going to keep watching her throughout the day to see if she continues to recover. Hopefully this yo yo temp will stabilize. Thanks for the help.Click image for larger version
Name:	ImageUploadedByForest River Forums1441630331.938295.jpg
Equalizer E2 Hitch
Old 09-07-2015, 11:41 AM   #4
GASPEDDLER's Avatar
Well it's back up in the fifties again. Tried to buy a new thermistor but can't find an open RV supply center.
Equalizer E2 Hitch
Old 09-07-2015, 05:46 PM   #5
GASPEDDLER's Avatar
I've gone ahead and disconnected the thermistor at its plug in point on the circuit board behind the Fridge unit. My understanding is the system should cool at 100% and if the cooling system is functioning should get well below normal operating temperature. Anyone see a problem with this method of testing the thermistor?
Equalizer E2 Hitch
Old 09-07-2015, 05:52 PM   #6
nomad297's Avatar
That is the easiest way of testing the thermistor.
Bruce
Old 09-07-2015, 05:54 PM   #7
GASPEDDLER's Avatar
Thanks Bruce, I'll report back with any findings.
Equalizer E2 Hitch
Old 09-14-2015, 04:44 AM   #8
Waiting for a report
Old 09-14-2015, 06:32 AM   #9
TURBS's Avatar
http://www.snip-the-tip.com/cgi-bin/articca.cgi
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
Old 09-14-2015, 06:58 AM   #10
Georgia Rally Coordinator
aceinspp's Avatar
You mentioned the freezer was fine. I'd find a new thermometer and try that also seeing how freezer doing fine. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 30
cooling, dometic
