Old 04-11-2012, 08:31 PM   #1
dometic refrig doesnt cool
Hi everyone; have a 2012 georgetown with 2 door dometic fridge. digital display lights but unit will not cool on either electric or propane. any ideas?
ltypd is offline   Reply With Quote
Old 04-12-2012, 04:27 PM   #2
rracer5's Avatar
First time using it?
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 04-12-2012, 04:56 PM   #3
TURBS's Avatar
How long did you start it before you checked it?
Old 04-12-2012, 05:49 PM   #4
tncruiser's Avatar
my dometic quit 2 days out on our way to fl for a month, we used the freezer as an ice chest for 5 weeks, when we returned dlr fixed it no charge ,dometic has a 2 yr warranty
on mine the cooling unit went bad,a little disappointed but resole was good and those things happen.
brianj
liven life in east TN and wherever my
2011georgetown280ve, and
2016 fordexplorer and hemi RAM
take us
tncruiser is offline   Reply With Quote
Old 04-12-2012, 08:18 PM   #5
Stevea1956's Avatar
Could you give us more details?
Is it cooling at all or just not cooling enough?
How long did you let it run without opening the doors?
The more information you can provide the better your chances of getting an accurate reply.
Steve & Lauren
2011 Windjammer 3065W
2012 Ram 3500, 6.7 Cummins
Stevea1956 is offline   Reply With Quote
Old 04-13-2012, 02:51 PM   #6
flame did not ignite on propane . was plugged in for 8 hrs. digital display of temp. went up not down. on slight incline but according to dealer should not be enough to keep from working
Old 04-13-2012, 03:13 PM   #7
Would be heading to the dealer. Iceboxes went out in the late 40's and block ice is hard to find.
Old 04-13-2012, 04:46 PM   #8
Stevea1956's Avatar
Yup... let the dealership worry about it.
Steve & Lauren
Old 05-02-2012, 07:45 PM   #9
DLC678's Avatar
You may have a reset on your system somewhere - CHECK THE OWNER'S MANUAL. If ours tries 3 times to start on propane, without the propane reaching the unit, it trips and has to be reset.
We have never been able to get ours to cool if we try to start it on A/C. ..... always have to cool it down on LP mode first.
Good Luck!
DLC678 is offline   Reply With Quote
Old 05-02-2012, 08:44 PM   #10
Herk7769's Avatar
Some troubleshooting tips to accurately report to your dealer so they can order the correct parts.
Name:	120 VAC Fuse.jpg
ID:	13126   Click image for larger version
Name:	120 VAC fuse holder.jpg
ID:	13127   Click image for larger version
Name:	RV evaporative Fridge.jpg
File Type: doc Fridge Operation and Trouble shooting.doc (356.5 KB, 52 views)
HAM CALLSIGN - KC3FFW
