Old 02-26-2019, 11:55 PM   #1
Dometic refrigerator
I want install a small fan inside my frig. to the coil inside. To do this I need to put a hole through the case. My question is: I am assuming the box is just an insulated box with nothing between the inside and outside except insulation, so can I just drill a hole anywhere (missing the inside and coils that I can see) to run my wires?
Quail is offline   Reply With Quote
Old 02-27-2019, 06:46 AM   #2
Witch Doctor's Avatar
I don't know if I would do that, other options are the 12V light inside or I ran the wire down the drain tube, never a problem, I have did it both ways.
Coachmen M/H
Concord
2018 / 300 DSC
Old 02-27-2019, 07:29 AM   #3
I have no light in mine. The drain tube is a good idea.
Old 02-27-2019, 08:48 AM   #4
cavie's Avatar
follow the thermistor wires.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 02-27-2019, 09:35 AM   #5
Head Rambler
It would help us to know what model fridge you have. That way we would know what's available that you could tie into, or if running a wire through the wall would pose a problem.
Gotta go campin!
Old 02-27-2019, 10:03 PM   #6
I will look the next time I go in it.
Old 02-27-2019, 10:19 PM   #7
Platokidd's Avatar
Was lucky enough to have a plug , removed it ran the wire and filled the hole.
Get a fan with a light.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
R.I.P. Luke the campin dog
Old 03-22-2019, 07:37 PM   #8
Lets go camping!
str8t six's Avatar
what model fridge do you have? you dont have to drill any holes, you can just tap power off from the inside light.
2014 Rockwood Mini Lite 2504s
2016 Ram 3500
str8t six is offline   Reply With Quote
Old 03-22-2019, 10:05 PM   #9
No inside light, I just got the fan so I will use the drain.
dometic, refrigerator
