Old 09-15-2013, 03:20 PM   #11
TURBS's Avatar
Originally Posted by Greytdogs View Post
That's what they told me. They would sell me a fan for $99.00 if I wanted to buy it and install it myself.
You can buy 10 fans for that on the cheap end.
I put two fan externally and one in the fridge internally and spent $25.00 .
Old 09-15-2013, 03:22 PM   #12
That's my point. Outrageous, isn't it? Can you tell me where you purchased your fans? I may have to do that also.
Jeff, Molly, and our 3 rescued canines..Abby, Presley, and Brad the Greyhound.
2014 Forest River Classic Super Lite 832IKBS
2013 GMC Sierra
Greytdogs is offline   Reply With Quote
Old 09-15-2013, 03:49 PM   #13
TURBS's Avatar
Www.tigerdirect.com
Old 09-16-2013, 09:12 PM   #14
HemiCab's Avatar
turbo was there a piece of wood or paneling in the same place where you have mounted your fans? I looked at mine to see about doing your mode but there was a board blocking the opening. I did mount some fans to the cover that would blow air upwards. The fans I mounted are to be laid on top of stereo components to extract the heat, so far not a noticeable difference.
Thanks HC
2008 Dodge Ram 2500 QC CTD 4x4
2014 Cherokee 284BH
Equalizer 1,200/12,000 WDH
TST 507RV TPMS
MaxBrake BC
HemiCab is offline   Reply With Quote
Old 09-16-2013, 09:20 PM   #15
TURBS's Avatar
Thanks HC
Yes that board was already there it comes out with two or three screws that are hard to see.
I believe it to be 1/8" luan or plywood.
Let me know if I can be of more assistance.
Old 09-16-2013, 09:51 PM   #16
HemiCab's Avatar
turbo thanks. I will review your post and see if I can go from there. Right now I will look for the wiring to the board for power. The 2 fans I have tried has not kept the temp below 40 during the day with the thermistor at the top of the fin. So I am hoping the larger volume fans will help (2 fans at 17 cfm ain't much).
HC
2014 Cherokee 284BH
TST 507RV TPMS
MaxBrake BC
Old 09-17-2013, 06:47 PM   #17
Fridge reset
Originally Posted by Fiddler8 View Post
Referring to the battery going completely dead requiring the propane side of the fridge having to be reset... Would this also occur if you remove the battery for winter storage and or maintenance?
The reset only happens when the fridge is requesting electricity from the battery and the battery is dead. If you manually turn off the fridge then I have not had the issue.
wheelmangg is offline   Reply With Quote
Old 10-23-2013, 03:59 PM   #18
New issue with the fridge
Looks like the electric side of the fridge is operating sporadically. No problem if we stay on propane side. Anyone else seeing this issue. 2013 Columbus Palomino 365RL.
Old 10-23-2013, 06:05 PM   #19
Lynkage's Avatar
For really great very long lasting fans look for Sanyo Denki or Nidec fans. A little more money but more air flow at a 30-32 db rating which is very quite.
9S0924L401 Sanyo Denki | Mouser
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
