Old 09-04-2013, 08:00 PM   #1
Fiddler8's Avatar
Dometic Refrigerator
I have the double door Domectic refrigerator and it makes a lot of noise when operating. The refrigerator has been operating for a week after I took delivery of the Toyhauler which is a new 2013. It cools to the set temperature but is noisy. Anybody experience any noise coming from their Domectic refrigerator?
Fiddler8 is offline   Reply With Quote
Old 09-13-2013, 10:18 AM   #2
Kampnnit's Avatar
The only noisy should be coming from cooling fans in the back of the unit. The fans are the same type used in computers.
Kampnnit is offline   Reply With Quote
Old 09-13-2013, 10:29 AM   #3
TURBS's Avatar
Replace there junk cheap fans with high quality ball bearing fans of equal size and you'll be fine.
I understand that it may be under warranty but there just going to stick the same fan in.
Turbs
Old 09-13-2013, 10:34 AM   #4
I heard that Dometic would provide quieter fans if asked.
Old 09-13-2013, 10:41 AM   #5
TURBS's Avatar
Quite possible.
Old 09-14-2013, 11:41 AM   #6
Dometic Fridge problems
We have had a couple of failures above the noisy fan which I am told is normal? Our service location had to run a separate electrical supply with an inline fuse as Forest River had the fridge on a line with other electrical components. This was done after a lower circuit board shorted out before the fuse on the circuit board blew. There was a black burnt spot on the board just in front of the fuse. (hopefully that was not a potential fire). Second failure was my own fault but a word to the wise here - If your trailer battery goes completely dead, the propane side of the fridge will not work and the system will need to be reset.
2013 365RL Columbus. 93 days on the road and counting this year.
wheelmangg is offline   Reply With Quote
Old 09-15-2013, 07:56 AM   #7
Fiddler8's Avatar
Referring to the battery going completely dead requiring the propane side of the fridge having to be reset... Would this also occur if you remove the battery for winter storage and or maintenance?
Old 09-15-2013, 02:40 PM   #8
I am currently dealing with the Dometic fan noise problem. Mine is on a slide out. I spoke to Dometic on Friday about it. They will sell me one for $99.00 but will not send me one on warranty. They will only send it to a dealer to be installed which they are going to do. I will try this once and if I get another noisy fan then I will do the computer fan install myself as suggested by other posters. This one is made in ......guess where.....China. Ah, the joys of warranty claims.
Jeff, Molly, and our 3 rescued canines..Abby, Presley, and Brad the Greyhound.
2014 Forest River Classic Super Lite 832IKBS
2013 GMC Sierra
Greytdogs is offline   Reply With Quote
Old 09-15-2013, 03:08 PM   #9
TURBS's Avatar
There going to sell you a $99.00 fan ?
Old 09-15-2013, 03:15 PM   #10
That's what they told me. They would sell me a fan for $99.00 if I wanted to buy it and install it myself.
2013 GMC Sierra
Old 09-15-2013, 03:20 PM   #11
TURBS's Avatar
You can buy 10 fans for that on the cheap end.
I put two fan externally and one in the fridge internally and spent $25.00 .
Old 09-15-2013, 03:22 PM   #12
That's my point. Outrageous, isn't it? Can you tell me where you purchased your fans? I may have to do that also.
2013 GMC Sierra
Old 09-15-2013, 03:49 PM   #13
TURBS's Avatar
Www.tigerdirect.com
Old 09-16-2013, 09:12 PM   #14
HemiCab's Avatar
turbo was there a piece of wood or paneling in the same place where you have mounted your fans? I looked at mine to see about doing your mode but there was a board blocking the opening. I did mount some fans to the cover that would blow air upwards. The fans I mounted are to be laid on top of stereo components to extract the heat, so far not a noticeable difference.
Thanks HC
2008 Dodge Ram 2500 QC CTD 4x4
2014 Cherokee 284BH
Equalizer 1,200/12,000 WDH
TST 507RV TPMS
MaxBrake BC
HemiCab is offline   Reply With Quote
Old 09-16-2013, 09:20 PM   #15
TURBS's Avatar
Thanks HC
Yes that board was already there it comes out with two or three screws that are hard to see.
I believe it to be 1/8" luan or plywood.
Let me know if I can be of more assistance.
Old 09-16-2013, 09:51 PM   #16
HemiCab's Avatar
turbo thanks. I will review your post and see if I can go from there. Right now I will look for the wiring to the board for power. The 2 fans I have tried has not kept the temp below 40 during the day with the thermistor at the top of the fin. So I am hoping the larger volume fans will help (2 fans at 17 cfm ain't much).
HC
2014 Cherokee 284BH
TST 507RV TPMS
MaxBrake BC
Old 09-17-2013, 06:47 PM   #17
Fridge reset
The reset only happens when the fridge is requesting electricity from the battery and the battery is dead. If you manually turn off the fridge then I have not had the issue.
Old 10-23-2013, 03:59 PM   #18
New issue with the fridge
Looks like the electric side of the fridge is operating sporadically. No problem if we stay on propane side. Anyone else seeing this issue. 2013 Columbus Palomino 365RL.
Old 10-23-2013, 06:05 PM   #19
Lynkage's Avatar
For really great very long lasting fans look for Sanyo Denki or Nidec fans. A little more money but more air flow at a 30-32 db rating which is very quite.
9S0924L401 Sanyo Denki | Mouser
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
