Originally Posted by cmptrkd
I have the same exact problem. Dealer has worked with it twice. I was putting my phone in the fridge on video camera mode and you could see the door close and not hit the light. If you push on that edge of the door, it will make contact and shut off the light. .
Took your advice on the video the other day. Did it after we got home and the fridge was unloaded and warm, and the light actually does go on and off when the door is opened and closed. Funny how when the fridge is active and full of food, the light fixture lens is hot every time I open the door. Could it be a thermal expansion/contraction problem, or possibly things shifting due to weight of contents of the fridge?
Just does not make sense that the lens would be hot.
Next I'll do the same test with the fridge loaded. 1st of August is our next trip.
