Old 06-08-2014, 08:32 PM   #41
dcheatwood's Avatar
Originally Posted by rburns4147 View Post
I cut the connector off the old fan, then wired both new fans to the old connector with solder and shrink wrap tubing. .
I'd love to see how and where you mounted yours. I have the fans and hope to finally install tomorrow. Got any pics?
Sent from my XT907 using Forest River Forums mobile app
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 06-08-2014, 08:55 PM   #42
CCRVOC
Ramblin Recks's Avatar
Originally Posted by Nortie16 View Post
We had our new trailer out for the first extended trip last week and I certainly noticed that noisy (high pitched whirring sound) that others have mentioned here. It did stop at those times when the outside air temperature was lower and, I'm assuming, when the fan could shut off.
Is this noise caused by the fan causing the metal housing bracket to vibrate?
Sounds like others have developed some great fixes for this issue. A bit of advice on this would really be appreciated.
My fridge is in the slide, and I have two (a lower and an upper) exterior vent cover. When I take off the upper cover, there's a kind of shroud made of two pieces of thin panelling. If I look over top of this I can just see the fan. I've attached a picture of what I see when I take off the vent cover. The top piece of panelling is just attached to the bottom piece with three screws. I can remove that piece easily, however it would be still be a challenge with the bottom piece in place to get my hands/tools inside to do what is needed.
Where is this bottom piece attached and is there a way to remove it, or will I need to work within that opening (five inches or so)?
Thanks!Attachment 54652
I used a razor knife to cut the paneling out. I disconnected the old fan and replaced it with 2 quiet high flow fans. Then I used some roofing flashing to make a baffle at the top the refer to help "funnel" the air flow out the vent. Huge improvement for little effort and $$..
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB, 4x4, 3:73, Retrax Pro, Q20, TST507, Garmin RV760, Sleek 4g
2014 Cedar Creek, 36CKTS, 640w Solar, TriStar MPPT 60, Magnum 2000w, PI EMS, WiFi Ranger Elite, Sleek 4g, Wingard DTV Traveler
Retired Army in 1995, and now retired in 2016
Ramblin Recks is offline   Reply With Quote
Old 06-08-2014, 09:17 PM   #43
dcheatwood's Avatar
That's exactly what I intended. Thanks.
Old 06-08-2014, 09:55 PM   #44
onetonford's Avatar
This is how I put mine looking down from top cover because my refrigerator is mounted in the slide it was too hard to go from the top so I ended up removing refrigerator six screws and the gas and electric lines and it slides right out then was easy to get to.
Name:	Fans Installed 5.jpg
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 06-09-2014, 05:22 AM   #45
Make sure you get some pics as you do it. I have been waiting to see how yours turned out before starting on mine as I am technologicly challenged
2014 Crusader 325res Touring Edition
2003 Silverado Duramax 6.6 Dually Longbed 2wd Crew Cab
RickV is offline   Reply With Quote
Old 06-09-2014, 02:33 PM   #46
dcheatwood's Avatar
OK. Got them installed this morning. Took about 4 hours but there was a lot of head scratching and problem solving (thinking) time involved.
First I lowered the wood panel for better access to the top vent behind frig on back of slide out.
Then removed old fan and thermistor.
Checked connections with voltmeter and found that fuse was burnt just at the positive terminal in lower vent. Direct connection showed fan does work so decided to use it still in a new location.
Next, screwed a small lightweight board approx 3/4" X 1.5" and 15" long to the holes where the original fan was fixed. Used this as a mounting base for all three fans.
[ATTACH]Click image for larger version
Mounted original fan in center with original hookup including thermistor.
Direct wired two new fans to pos & neg with a switch in lower area. I can turn these on as needed on HOT days or when no shade available.
Picture showing difference in size - new and old fans.
Here's where the head scratching started. All three fans blow downward. I tried wiring them backwards and they will not run at all. Only +to+ and -to-. They are mounted upright. If I turn them over, the bearing area is exposed to weather more. There is a shroud type cover in the center of each fan that seems to indicate up and down. Why won't they run backwards when wired backwards? At this time, a huge storm blew in with nearby lightening, and I dismounted my ladder olympic style. Will think more on this issue as oright now, all three fans are blowing downward and that is not what I want. Hope someone has some advice.
Here's a close up of the board mounted.
Old 06-10-2014, 09:33 PM   #47
dcheatwood's Avatar
Checked temps behind frig with touchless thermometer. Boiler ? Right side is 125 and tank on lower left is 115. 10 difference doesn't seem bad.
But frug is 45 and freezer is 10.
I think tomorrow I'll move 2 new fans down to blow on lower fins and leave original on top fins. Also gonna trim out the wood panel in top vent. It blocks 60-70% of vent openings. Not sure why.
Old 06-11-2014, 07:50 AM   #48
dcheatwood's Avatar
Wow! Put thermometer in freezer over night. -2 this morning. Gonna put it back in frig and check bit again.
Old 06-11-2014, 08:08 AM   #49
Might want to get some alum flashing and fashion a curved deflector at the top to get the air movement a little better. I found mounting the fans down low, just above the burner, cools the entire back a lot better than trying to pull the air up and out the vent.
Old 06-11-2014, 08:26 AM   #50
dcheatwood's Avatar
I just went out to look at that very option. Seems like no where to mount the fans low.
dometic, refrigerator, fan
