Old 06-11-2014, 11:01 AM   #51
Originally Posted by dcheatwood View Post
I just went out to look at that very option. Seems like no where to mount the fans low.
Mine is a Norcold.
Name:	Dual fans2.JPG
ID:	54949   Click image for larger version
Name:	One 80mm and one 90mm.JPG
Old 06-11-2014, 11:47 AM   #52
dcheatwood's Avatar
Thanks OC. I'm still looking for mounting space. Yours looks adequate in that space. I have to find the space.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 06-12-2014, 05:11 AM   #53
I have seen OC's posts on low mount before and immediately when out and looked at mine. There is no where down low to mount them on the 1350
2014 Crusader 325res Touring Edition
2003 Silverado Duramax 6.6 Dually Longbed 2wd Crew Cab
RickV is offline   Reply With Quote
Old 06-12-2014, 06:03 AM   #54
How about a picture?
Old 06-12-2014, 06:06 AM   #55
My frig fan was loud also. I took top outside vent out and looked in and fan stopped. Guess it burnt out or cooled down enough to turn off. Have not heard it since. 11 months now.
Update: Not cooling well in firg. Freezer is -2 degrees and frig is 45. Installed two more fans in top to pull air thru but did not help frig. Trying to find a locatio to mount the new fans lower to blow from bottom up.
Sent from my XT907 using Forest River Forums mobile app
Are you using fans with a high CFM. I had problems last year while on vacation in our fifthwheel. I couldn't get the refrigerator temp below 61 degrees. Had to keep food in coolers. When I got home, I pulled the Dometic refrigerator out and discovered that there were no fans at all. I ordered 5 High CFM fans, wire cables, AC/DC converter 2amp, switch, and power hub strip from Coolerguys.com, (about $100 invested). I made brackets from Aluminum angle iron purchased from Lowes. Three fans at top of vent shaft and two fans between coils on rear of the refrigerator. Placed a strip of two sided thick foam like tape on the rear bracket to obsorb any vibration of it next to the unit. The rear bracket is not held only by the foam like tape. The ends of the bracket are bolted to the refrigerator. When we get to our site I flip the switch to turn them on and it stays on until we break camp. Stays around 34 degrees in the hot heat. These fans also help it to cool down a lot quicker. Good luck with your set up. My fans are blue LED fans also. I can peek up through from the outside and see them running.
OKI Marine is offline   Reply With Quote
Old 06-12-2014, 08:06 AM   #56
Sorry about the small size but I uploaded them to forum and they got shrunk down you can open the album and see bigger pics. http://www.forestriverforums.com/for...lbums1910.html
Here it is:
Tried to get one looking in and up:
What about mounting a 90 Degree bracket to this:
Old 06-12-2014, 08:20 AM   #57
RickV, just above the horizontal black tube.
Old 06-12-2014, 02:56 PM   #58
dcheatwood's Avatar
Well. I just cut out top panel to allow for more air exit and placed a piece of roof flashing above it all. Frig at 42 this morning. Has come down to 38 in past 20 minutes. Watching.
Sent from my ASUS Transformer Pad TF300T using Forest River Forums mobile app
Old 06-16-2014, 11:15 AM   #59
dcheatwood's Avatar
Still can't get frig temp below 40į, even with 3 fans on. So this morning I direct wired elected heating element as described in video I watched. Hoping.
Old 06-16-2014, 04:33 PM   #60
Freds342's Avatar
Dometic recommends that any vent fans be installed well above the burner in the vent, not below the burner or any other place in the compartment.
They also have stated, on other forums, that proper installation design doesn't require fans. (I guess they didn't expect reefers in slides!)
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline   Reply With Quote
dometic, refrigerator, fan
