Old 06-16-2014, 04:44 PM   #61
Originally Posted by Freds342 View Post
Dometic recommends that any vent fans be installed well above the burner in the vent, not below the burner or any other place in the compartment.
They also have stated, on other forums, that proper installation design doesn't require fans. (I guess they didn't expect reefers in slides!)
I mounted my two fans directly above the burner so they blow the entire length and width of the back.
Old 06-17-2014, 08:06 AM   #62
dcheatwood's Avatar
Originally Posted by dcheatwood View Post
Still can't get frig temp below 40, even with 3 fans on. So this morning I direct wired elected heating element as described in video I watched. Hoping.
Sent from my XT907 using Forest River Forums mobile app
Direct wired heat element all night. 20 hr's. Only got down to 40 in frig. Guess heating element is the problem? Time to take it in for service.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
dcheatwood is online now   Reply With Quote
Old 06-27-2014, 02:21 PM   #63
Platokidd's Avatar
dcheatwood, what fridge do you have? I have a Dometic RM 1350. I have notice temp getting up to 45 deg on hot days.
I did add screens to my openings in the vents top and bottom. Wondering if Im restricting too much air movement.
My fans do blow upward. I have no wall or baffle in my top vent like in your pic.
Just a note on that: dealer had to make a wall of caulking (1 1/2" high) to stop rain water from coming in the top vent and running down on my floor inside.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 06-27-2014, 06:25 PM   #64
PhoneDude 8289's Avatar
A good airflow across the back of the unit is much needed to dissipate the heat.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 06-28-2014, 02:01 PM   #65
dcheatwood's Avatar
Mine is the dometic 2652 if I'm reading it correctly. Thats the number on the tin plate blocking the flue. I've made several mods trying to get it to cool like my others did. The new thermistor is the only one that made an obvious instant improvement. I'm still waiting for a hot day to test it.
Old 06-28-2014, 02:07 PM   #66
Have you tried the dual fans on the back?
Old 06-28-2014, 02:21 PM   #67
dcheatwood's Avatar
Yes. I posted pictures and step by step details of the mod. Didn't seem to help. I have the ori fan still on its auto system and manual switch on the two new fans. I really believe I had a bad thermistor but can't be sure until weather gets hot here again. With the new thermistor, on factory setting, it's holding down to 28 at night and up to 35 in day but cool days have been in mid 70s all week with rain and cloud cover. Should warm up today and tomorrow.
Old 06-28-2014, 02:24 PM   #68
Yours is unique as the 1st I've heard with 2 or 3 fans blowing CONTINOUSLY on the back did not lower the inside box temperature.
Old 06-28-2014, 08:40 PM   #69
dcheatwood's Avatar
They'll surely matter on a hot day but it would not come down cold like it is now.
Old 06-29-2014, 08:10 PM   #70
Plain Old Member
My fridge is a DM2862. I hadn't seen any cooling problems, but, it hasn't really got hot yet. I threw this computer fan in there right before we left the other day. Just mounted it to a piece of aluminum flat bar I had and screwed it to the frame work. Tight fit, but it doesn't touch anything. I just mounted a toggle switch for now. Hope to put a thermostat switch and neaten up the whole deal later on.
Only fridge I had problems with as far as cooling goes, was the one in our forester, in the slide. In that case, replacing the thermistor with the adjustable one (snipthetip.com) did the trick.
ID:	56721   Click image for larger version
Name:	Switch and Fan.jpg
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
dometic, refrigerator, fan
