Old 05-22-2014, 03:58 PM   #1
Dometic Refrigerator Noisy Fan
Have had our Piper 355RE for a month now. Fridge fan is noisy like it may be bad. Tech said it's normal to make that noise. The wide isn't buying that answer because our last unit had a domestic and not once in 11 years could we ever hear it running.
Gomer0824 is offline   Reply With Quote
Old 05-22-2014, 07:53 PM   #2
This is common there are many threads on this problem and fixes. Do a search and you will find them. BTW my dealer said the same thing.
2014 Crusader 325res Touring Edition
2003 Silverado Duramax 6.6 Dually Longbed 2wd Crew Cab
RickV is offline   Reply With Quote
Old 05-22-2014, 11:06 PM   #3
dcheatwood's Avatar
My frig fan was loud also. I took top outside vent out and looked in and fan stopped. Guess it burnt out or cooled down enough to turn off. Have not heard it since. 11 months now.
Update: Not cooling well in firg. Freezer is -2 degrees and frig is 45. Installed two more fans in top to pull air thru but did not help frig. Trying to find a locatio to mount the new fans lower to blow from bottom up.
Sent from my XT907 using Forest River Forums mobile app
2018 Forester 3011 DS
Old 05-27-2014, 08:00 PM   #4
We have a 2014 sandpiper 380bh5 and our frig is doing the same thing. It is so loud and does not cool anything like our old frig did. I'm really disappointed in this new frig. Where can we find info on what to do about it?
jabbo is offline   Reply With Quote
Old 05-27-2014, 08:08 PM   #5
Disconnect the factory fan, buy 2 ball bearing computer fans and put them just above the burner facing up and connect them to the factory fan wiring.
Problem solved for around $20 or less.
Old 05-27-2014, 08:19 PM   #6
camper1999's Avatar
I did the same and let the new fans run all the time. I left the factory fan in for back up and it never goes on with the others running. The refrigerator it colder now.
Sent from my SPH-L720 using Forest River Forums mobile app
2011 GMC 2500HD Diesel
Old 05-27-2014, 09:30 PM   #7
dcheatwood's Avatar
Mine was a little iffy when I hooked up last Friday for a weekend run. Thermometer would show frig around 45-49 and freezer was at 20-24. After towing for 1.5 hours, the frig was reading 30. Evidently the added airflow of traveling 50-60 mph aided in cooling. So I will be getting the two fans as suggested by oldcoot.
Old 05-28-2014, 06:00 AM   #8
Where do I need to look for the 2 ball bearing computer fans. I would really like to get this problem fixed. Thanks again.
Old 05-28-2014, 06:17 AM   #9
KyDan's Avatar
Go to NewEgg.com or Tigerdirect.com and search for case cooling fan.
There are lots! I donno about 2 for $20 with ball bearings but they have
several with sleeve bearings in that price range.
Good luck! (And watch out for that auto correct spell checker!)
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 05-28-2014, 06:21 AM   #10
StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan w/ LP4 Connector - System fan kit - 80 mm at TigerDirect.com
Price: $6.18
dometic, refrigerator, fan
