Old 06-26-2015, 05:30 PM   #1
Dometic Refrigerator Temperature
Where do I go to find out what the low temperatures should be in a Dometic Model RM2862? Thanks: crying:
dnismenace is offline   Reply With Quote
Old 06-26-2015, 05:44 PM   #2
Flybob's Avatar
How about a little more info, What is temp now. Too warm? Too Cold? Have you adjusted temp slide?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-26-2015, 05:50 PM   #3
I think it is too warm. I would like to know what is an expected temp for a Dometic Refrigerator in 90-95 degree weather. Thanks
Old 06-26-2015, 05:59 PM   #4
Yesterday, I checked my Dometic refrigerator using the coldest setting.
The outside temperature was in mid-90's. The freezer was 15 and the lower refrigerator was 30. Which was much colder than it needed to be. I did not have any food in it.
I was just checking it.
txredfish is offline   Reply With Quote
Old 06-26-2015, 06:04 PM   #5
Thanks, That is what I am looking for. My fridge is in the mid to upper 40's and the freezer is in the lower teens.
Old 06-27-2015, 10:10 AM   #6
At 10:00 last night the fridge was in the mid 50"s and the Freezer was in the upper 20's. Am going to put it on gas in a few minutes and see if it operates any better. Will update later today. Thanks.
Old 06-27-2015, 10:22 AM   #7
Flybob's Avatar
Where is the temp slider set ? It is on the cooling fins. Is there anything in the fridge?
TST Tire Monitors
2 100W solar panels
Old 06-27-2015, 10:58 AM   #8
Sorry I did not respond yesterday Flybob. The Temp slider is between the first and second fins and as high as it will go without being in a strain. The bottom is about 2 inches from the bottom of the fin.
At 10:15 this morning the temp in the freezer was at 2 degrees F and the fridge was at 46 degrees F. These readings are weird.
The button was out on the chimney sensor. I pushed it in and took these readings shortly after. Then I switched it over to gas to see if it performed better on gas.
That is where it stands now. Thanks
Old 06-27-2015, 10:59 AM   #9
Also the temperature setting is at its highest setting
Old 06-27-2015, 11:01 AM   #10
TURBS's Avatar
Is fridge and freezer full of food?
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
dometic, refrigerator
