Old 11-26-2018, 09:35 PM   #1
Dometic Refrigerators / Rockwood's Design
It seems to me that when one breaks it is best to just replace the entire unit.
I have had nothing but problems with getting replacement parts and reputable service reps to fix the unit (DM2852).
Plus the cabinet in which the unit is housed in has an 11/2 inch drop from the front of the cabinet to the back which automatically makes the unit not level even though the trailer is level.
Perplexed with Rockwood's design and definitely perplexed with Dometic Customer Service.
NS74CH is offline   Reply With Quote
Old 11-27-2018, 10:01 AM   #2
Head Rambler
Are the parts you're trying to get parts for warranty repair?
What parts have you needed?
Can you post a pic of the cabinet and the unlevel issue?
In most cases the inside of the cabinet doesn't matter as the fridge is mounted by the frame at the front, so as long as the cabinet front is plumb when the RV is level, the fridge will be level.
Gotta go campin!
Old 11-27-2018, 10:21 AM   #3
How old is your R/V?
Dometic has been super to me the couple times I've contacted them.
A 1-1/2" drop seems awfully excessive. As mentioned, could you post photos of the install?
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 11-27-2018, 01:31 PM   #4
47driver's Avatar
I'm taking my 2017 back in for the third time to fix the frig. Of course, they now say that I'm out of warranty. Funny, it has the same problem EVERY time.
1989 Viking Li'l gasser Pop up
1993 36 Thor Class A
2009 16 Kodiak Cub Hybrid
2010 24 Fleetwood Pegasus
2017 24 Flagstaff Shamrock 23IKSS
2015 Ram 3500 Diesel MegaCab 4X4 SRW
47driver is offline   Reply With Quote
Old 11-27-2018, 02:42 PM   #5
Mad Cow's Avatar
Whenever one of those goofy propane Dometic fridges taps out, I always suggest getting a AC/DC compressor fridge from Dometic. Direct fit replacement for the propane variety. Only use about 4AH in DC mode. Not as fickle as the propane ones in hot summer situations. No internal air flow cooling issues.
Mad Cow is offline   Reply With Quote
Old 11-27-2018, 03:09 PM   #6
47driver's Avatar
Hmm...sounds like an option.
Old 11-27-2018, 03:22 PM   #7
My "goofy propane Dometic fridge" just completed it's 12th camping season without a hiccup.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 11-27-2018, 03:30 PM   #8
Mad Cow's Avatar
-- Chuck
And my Dometic compressor fridge has covered 908,000 miles of travel and has run 24/7 most of its life. Just a LED light replaced. And the compressor models operate up to 30 degrees off level.
Old 11-27-2018, 03:41 PM   #9
Head Rambler
Wow! Didn't take long for NS74CH's thread to get derailed did it?
Hopefully they'll come back and let us know more about their issue.
Gotta go campin!
Old 12-04-2018, 06:28 AM   #10
I can't tell from the post what outcome you are looking for.
In my 2 experiences with Rockwood and Flagstaff A-frames (both bought new), fridge performance was marginal because the installation didn't meet Dometic specs, and the plastic Dometic grills for the air flow were overly restrictive. These are both design and workmanship deficiencies. I downloaded the installation and operating instructions from the Dometic web site.
I was able to fix the workmanship issues myself with packing insulation into the voids around the fridge, sealing off and reducing the effective size of the rear compartment with Reflectix and furnace duct tape. On one, I had to extend the chimney exhaust towards the upper grill. And I added to and moved the baffle to meet Dometic specs.
The poor grill design - excellent at keeping water out, not so good at promoting good air flow - was solved with tie wrapping computer case fan(s) directly to the upper grill to push ot air out.
Although both were in warranty, I didn't see anybody caring enough to make all the changes, as the fridge performance was very inconsistent before I did the work.
After making the changes listed above, the fridges are rock solid performers, verified with a wireless thermometer inside the fridge.
just my thoughts and experiences
Fred W
then 2014 Rockwood A122 A-frame
now 2019 Flagstaff T21TBHW A-frame
dometic, refrigerator, rockwood
