Originally Posted by TURBS
No it can be blown out with compressed air from the outside access panel.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
The manual for the Dometic RM 1350 states to pull the flue baffle out use a flue brush, clean the flue from the top. Blow- ing compressed air into the flue will not properly clean soot and scale out of the flue tube. When I remove the upper vent cover, there is a piece of plywood, I guess, is used as a baffle covering a lot of the opening. With a mirror, I can see the top of the baffle where it would be pulled from. My thinking is to remove the upper vent frame, but am not sure if I would be able to move the plywood out of the way. I am hoping that someone that has a Sanibel of a unit installed in a slide can give me some tips on how to properly access and clean the flue.
