Old 07-31-2016, 01:23 PM   #1
Dometic RM 2652 Fridge
I am having trouble with the resettable ECO on the back of the fridge, wondering how to fix?
CasualT is offline   Reply With Quote
Old 07-31-2016, 01:28 PM   #2
Try YouTube?
ja4781 is offline   Reply With Quote
Old 08-01-2016, 03:30 PM   #3
Head Rambler
If it won't reset then you're only option is to replace it.
Since you've tried to reset it, you obviously know where it is so replacing it isn't much of a job.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-02-2016, 01:51 PM   #4
Jumped the switch and it still wouldn't work, guess I will get the cooling unit replaced, can't afford a new refrigerator!! Thanks for the input!
Old 08-03-2016, 11:29 AM   #5
Head Rambler
Give us more info on what isn't working.
Is neither gas nor electric working?
It could be the control board or a blown fuse or two.
Even if it's a control board, you can replace it with a Dinosaur control board.
Gotta go campin!
Old 08-03-2016, 07:31 PM   #6
Fridge
I got the cooling replaced, jumped across the ECO resettable and ranit for two hours, no cooling, found evidence of ammonia leaks, got it replaced today, will try it tomorrow to make sure it works. Watched the replacement process and could see major damage, pretty sure all is well now, will know for sure tomorrow!!
Old 08-04-2016, 08:01 AM   #7
Head Rambler
Thanks for letting us know what you found. Bummer that you had to replace the cooling unit.
Gotta go campin!
dometic, fridge
