Old 12-21-2018, 02:09 PM   #1
Dometic RM1350SLM cooling issue on electric, long post
Once again here asking help from the vast knowledge of you all. Problem: brand new (2019 sob 5er) 1350 will not cool the fridge on electric. Camper is level. Doors are sealed well. Got to camp, our maiden voyage, it's 60 degrees outside. Drive three hours to get here on propane, upon arrival the freezer is well iced, the fridge is at 35 degrees. Set up, unit is on auto so it goes to electric. We leave the camper for three hours, and now freezer is still frosty but fridge is now at 47 degrees. Panic sets in, I turn the unit back on propane, and within 4 hours fridge fins are frosty and temp is dropping. We've been at camp on propane for 5 days and all has been well. I don't want to risk a food spoil buy trying electric again. I have read and read but there seems to be conflicting information about possible problems. My understanding is it's possible the 130v fridge heater is not working, which would explain what we're experiencing. NO, I'm not going to take it back to the dealer; our delivery experience with them over PDI issues was less than, and they are three hours from home. I'm pretty handy at things, so fixing it myself is not a problem. Help always appreciated!
David and Vicki
8 year old Springer rescue Sydney
2018 Silverado LTZ 3500HD Dually Crew Cab Duramax/Allison stock "Polar Bear"
2019 Grand Design Reflection 337RLS "The Dog House II"
Andersen Ultimate 5th wheel hitch
EezTire TPMS
Springerdad is offline   Reply With Quote
Old 12-21-2018, 02:42 PM   #2
I don't have any idea when you first fired up the refrigerator but you do know about the frost reduction cycle?
I'll typically see temperatures of 42º-44º during this cycle, up from 35º normal.
This only affects the 'fresh' food compartment and may be why you seen good cooling in the freezer.
From the owners manual...
First paragraph is the ACUCS (automatic cooling unit cycling system)
Second paragraph pertains to running the unit in low ambient temperatures. (LAC)
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 12-21-2018, 02:44 PM   #3
2 ways to check if the 120V coil is working.
1) disconnect coil at the terminals and measure resistance. Resistance should be about 80 ohms, certainly no more than 120 ohms, and at least 40 ohms. Dometic manual will have figures for your model. If you have an open (very high resistance) you will get no heat in the chimney, and no cooling in the fridge.
2) set to max cool on AC and feel the chimney for heat after about 30 minutes. Should be warm-to-hot to the touch.
If the AC coil is good, and the fridge is not working on AC, check the voltage at the AC terminals on the control board - both input into the board, and output to the coil.
Then check the voltage where the fridge plugs in. Then finally check AC circuit breaker in panel is "on" - turn "off", then "on".
All the above assumes camper is receiving shore power - the microwave also needs 120V AC. If the microwave isn't working either, you have no 120V AC coming into the camper.
Hope this helps
Fred W
2019 Flagstaff T21TBHW A-frame
Old 12-21-2018, 03:42 PM   #4
cavie's Avatar
I have to move my thermister up and down. Mine cools colder on propane.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 12-21-2018, 04:11 PM   #5
My Dometic RM1350 doesn't have a sliding thermistor on the fins.
Old 12-21-2018, 04:11 PM   #6
Thanks. Yes, I did read that, but I have no way of knowing how many hours it has on it so far. It's possible it was doing a defrost. I may try 120 now that we're in for the day so I can watch it.
David and Vicki
EezTire TPMS
Old 12-21-2018, 04:14 PM   #7
Hope this helps
Fred W
Thanks Fred. I do have a DVOM with me.... but the rain showers are still washing over us so I never get enough time with it. Thank you for the specs! That's what I was looking for but saw all kinds of numbers that weren't helping.
Edit: We do have 120. The micro works, the water heater works, and we've been running two electric heaters almost the whole time we've been here. Brrrtr
David and Vicki
EezTire TPMS
Old 12-21-2018, 04:22 PM   #8
The defrost cycle has nothing to do with total cumulative hours... it's the hours from when turning it on each time after it has been turned off.
Old 12-21-2018, 04:27 PM   #9
Huh. I missed that one. Thanks for straightening me out.
David and Vicki
EezTire TPMS
Old 12-21-2018, 04:52 PM   #10
Platokidd's Avatar
We have a service manual for the 1350 in the library that may help.
Forest River Forums - Downloads - Dometic RM + RME1350 fridge SERVICE MANUAL
Good luck!
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
R.I.P. Luke the campin dog
cooling, dometic, electric
