Old 09-28-2014, 07:09 AM   #1
HarrynSally's Avatar
Dometic RM2652 Problems
My RM 2652 won't light, all it does is make one big click sound and that's it.
Was working fine 2weeks ago.
HarrynSally is offline   Reply With Quote
Old 09-28-2014, 07:12 AM   #2
tncruiser's Avatar
does it run on electric? if so it might be a irty burner or clogged flue
brianj
liven life in east TN and wherever my
2011georgetown280ve, and
2016 fordexplorer and hemi RAM
take us
tncruiser is offline   Reply With Quote
Old 09-28-2014, 07:13 AM   #3
Check out www.rvrefrigeration.com they also have you tube video.
Old 09-28-2014, 07:14 AM   #4
I checked the burner it's was clean
Old 09-28-2014, 07:17 AM   #5
And yes it does run on electric very well. Freezer at 9deg below and fridge at 28 deg above zero
Old 09-28-2014, 10:44 AM   #6
tncruiser's Avatar
your unit is defiantly not "shot" but the gas side does have a problem ,mine acts similar once it is cold on electric side ,gas will barely maintain temp on gas ,when I find the answer w/o spending $$$'s on a diagnosis I will let you know
brianj
take us
Old 09-28-2014, 10:45 AM   #7
Roger on the not spending $$$
Old 09-28-2014, 11:00 AM   #8
Witch Doctor's Avatar
Is your flue hot to the touch? There is a sensor located on it that will shut the gas off. If it is just cycling on and off and not reaching temp, it could be your probe that has to stay hot or it will shut down the gas also. You can pull the burner and clean it with either sand paper or a green pad. Your refer is not shot. But you do have a problem on the gas side as you stated. It also can just be the board. You should also have a sensor that will turn your fan on over the coil, also check the fan and that sensor.
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-28-2014, 11:24 AM   #9
I seen the sensor there is small button in the middle does it stick out or should be in?
I clean my Flue last month
Old 09-28-2014, 11:28 AM   #10
When the fridge would switch from electric to gas the igniter would click 3 to 4 times
now it only click once.
Old 09-28-2014, 12:08 PM   #11
That is the correct way, It will also lock out after 3x's then you have to shut it off and restart to reset it. I think the button is in. You should have 12V on each side or it is tripped or just could be weak. By pass the sensor by connecting the two wires together and see if you light off also check that sensor in the coil fin on top. You are losing 12v somewhere that is shutting your gas valve down. But from what you just said my money on the ignition system. which is the board or the probe.
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-28-2014, 12:42 PM   #12
There are 3 dimensions for the probe to be set to for it to operate. Get your manual out and start measuring. If even one is off, it will not work. It took me about 20 minutes to get them all correct when my unit was brand new. Once I got them set, it has worked flawlessly ever since.
Old 09-28-2014, 05:23 PM   #13
tncruiser's Avatar
did the problem start after cleaning the flue ,I believe there is a vent "restricter" to help keep the heat in that can become dislodged,the next step I am taking on mine is to go rooftop and remove cover to inspect flue
brianj
take us
Old 09-28-2014, 08:34 PM   #14
I will check next chance I get on the flue.
Old 09-29-2014, 05:46 AM   #15
I need to remove the fridge from the cabinet to run the wire for new fan inside.
I'll check the Flue then. I'll turn the power off 120 & 12 Volt to let it reset.
I tried to mess with it last week but I didn't have enough time to check everything.
