Old 07-20-2017, 11:03 AM   #1
depswha's Avatar
Dometic RM2852 Refrigerator will not come on
I have 118 volts coming out of the plug and going to the circuit board. Both fuses are good as they ohm out to 3 and 5.
I have 12 volts at the block where white wire and white with yellow stripe wire come out. This one has an inline 5amp fuse and it is good.
No power at the switch on the top left above the freezer door.
No lights on the control panel, inside light does not come on.
Any help would be greatly appreciated
depswha is offline   Reply With Quote
Old 07-20-2017, 11:17 AM   #2
Check your fuses again if they are not reading zero or completely closed then they are blown.
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 07-20-2017, 03:47 PM   #3
Agree with Todd. They can look good and be blown. I always check them with a meter.
If they are good unplug and replug the connections a few times to make sure they're making good connection.
Gotta go campin!
Old 07-20-2017, 07:50 PM   #4
depswha's Avatar
Ok I will try that.
Old 07-20-2017, 08:30 PM   #5
cheeseheadjim's Avatar
X3 on the fuses. I had a recent issue with the fridge not running on 120v. It would only run on propane. The 5A glass fuse on the control board looked fine but gave an intermittent open circuit reading when I checked continuity. I replaced it and voila, the 120v circuit worked.
2018 Flagstaff 25FKS
2015 Ram 1500
cheeseheadjim is offline   Reply With Quote
Old 07-20-2017, 08:41 PM   #6
Herk7769's Avatar
FYI - The fridge runs on 12 volts DC.
It HEATS with either 12volts DC and propane or 120 volt heater.
If you have no 12 volt DC you will not have a refrigerator at all.
This could be a blown 12 volt fuse that feeds the fridge since you don't get an AUTO light when pressed.
If you get an auto light at the "eyebrow" panel but no cold; check the stack over-temp breaker. (see photo)
Name:	Camper Fridge 007.jpg
ID:	145505   Click image for larger version
Name:	Circuit diagram (2).jpg
ID:	145506   Click image for larger version
ID:	145507   Click image for larger version
Name:	Fridge Controls 003.jpg
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 07-20-2017, 09:13 PM   #7
depswha's Avatar
Ok cool. Thanks!!
Old 07-21-2017, 05:42 PM   #8
I had a similar problem ended up being the heating element.
Bnrc73 is offline   Reply With Quote
Old 07-24-2017, 12:18 AM   #9
Tom48's Avatar
Mostly I want to see no ohms across a fuse, but I want to be looking at same voltage on both side as well. When in doubt pull it out to check for continuity. Should be a dead short across a good fuse. Zero ohms.
Tom48
In Sunny So Cal /w
Now in 2005 Holiday Rambler Ambassador DP and The Hot Air Balloon RESTLESS
NO MORE Tricked out
2017 Sandstorm 250 T.H.
Tom48 is offline   Reply With Quote
Old 07-24-2017, 02:51 PM   #10
Check your CFI BREAKERS IN THE BATHROOM. COULD BE TRIPPED. You could have more than one CFI outlet (I think that's what they are called) it's the breaker built into an outlet. Might be your problem
dometic, refrigerator
