Old 07-04-2016, 10:45 PM   #1
Dometic rm3962 fridge
I am completely lost. My unit cools on gas but not on electric. I have replaced the electric heating element and the control board in the back of the unit. Yet, my unit still does not cool on electric. Is there anything left to replace? Any ideas on what it could be?
crna72 is offline   Reply With Quote
Old 07-05-2016, 07:39 AM   #2
Mr. Dan's Avatar
We have read here about cases where the fridge cord was not even plugged into its outlet and other cases where that outlet was dead (not connected at power center or breaker was off or bad). Start by checking for 110v power.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 07-05-2016, 08:02 AM   #3
I did that. Outlet works, i plugged other devices into it and they worked. What about the circuit board on the inside of camper where the on/off switch is?
Old 07-05-2016, 08:14 AM   #4
Pickin' & Campin'
Have you done any kind of electrical tests to determine if AC is present at the control board/heating element?
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 07-05-2016, 08:20 AM   #5
Head Rambler
Have you checked for voltage at the element when it's calling for cooling?
Have you checked the thermistor?
Are you getting any error messages on the display?
You can find the service manual by searching for "Dometic rm3962 service manual". That will give you info on how to diagnose problems.
Gotta go campin!
Old 07-05-2016, 09:08 AM   #6
Wow! Thanks for the service manual! I didn't know such a thing existed. Tons of good info there. I'll check stuff out when i get home and let you all know what i find our.
Old 07-06-2016, 11:49 AM   #7
I used my multi-tester on it yesterday. Everything checked out except the button board on the inside. Neither the on/off switch or auto/lp switch had resistance. Have a new one coming in this afternoon. Hopefully this will fix the issue. I'll let you guys know and thanks for all the help.
Old 07-06-2016, 03:00 PM   #8
Head Rambler
Good luck. Hope that fixes it.
Gotta go campin!
dometic, fridge
