Old 07-09-2011, 09:33 PM   #1
Dometic Roof air thermostat problem
I have a new wildwood trailer that I went out today and tried to turn the AC on and the control pad was flashing E2. Any suggestions. I tried to resetting everything but it wouldnt work. I am having problems finding a solution.
Let me know Thanks
Daniel
firedaniel is offline   Reply With Quote
Old 07-14-2011, 06:14 PM   #2
Bump because its hot out here!
Old 07-14-2011, 06:23 PM   #3
Here is a thread were someone encountered the very same problem. Some ideas in it that you may find helpful.
Dometic AC
scor1pion is offline   Reply With Quote
Old 07-16-2011, 07:14 PM   #4
Well been digging all over the internet and if it is over 110 inside the camper the thermostat will flash E2. Dometic is aware of this and is replacing the thermostat. I actually was going to replace mine with a digital thermostat from homedepot but the one in the camper only has 3 wires on it. a 12+ comm and ground. I couldnt figure out how to adapt one. So my dealer has ordered a replacement.
I started it early this morning before the heat of the day and it was fine.
Does anyone know how to adapt a 3 wire dometic thermostat to a normal one?
Thanks guys
Daniel
Old 07-17-2011, 06:30 AM   #5
KyDan's Avatar
If you use the google search box at the top of this page and search
FRF for replace thermostat you will find several threads that might
be helpful.
Good Luck!
Peace!
Dan & Rita D
Blue Ox WD hitch
